Extending O2 Wire for header set up
Hello all, just installed the Fabspeed RSR headers and sport muffler kit on my 3.2.
Looks like i need to extend the O2 sensor wire quite a bit to get to the new location. Anybody konw if there is a extension or a longer wire or just splice and make it longer? Anything to be aware of? |
Does your sensor come with that typical old rubber plug?
If yes, then cut the line and enlarge using a simply wire with the same diameter and ... choose crimping for connecting the wire ends no soldering.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
