Lower idle when removing oil cap
While I checked the oil level after warming up, I noticed that the idle RPM dropped somewhat and became less stable as soon as the cap was off. When putting back on, immediately RPM reset to normal. . It's a 3.2 86 Targa. What is happening here?
Every 911 I've ever had does this. I just assumed pressure is being released with the cap off.
Completely normal, you've created a vacuum leak when cap is removed. I'd be more concerned if it didn't do that.
Walt 82SC 3.0 81SC 3.6 |
If I was told correctly, that lowering of idle means your vacuum system is in good order. If it didn't change, it would mean air is getting into the system from another area. I expect one of the pros will be along in a bit to confirm/correct.
here is some reading...
Ivan https://www.justanswer.com/porsche/8f1rm-porsche-911-targa-carrera-1987-porsche-911-targa-carrera-i-m.html
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
great feedback from all, always good the learn that what I thought to be a problem is actually dead normal
As everyone has responded, a slight drop in RPM’s is normal. However, if it is stalls you should check to make sure that the brass Venturi that is inserted in the oil hose leading to the crankcase isn’t missing or out of position as the Venturi is in place to limit the amount of air that can be drawn into the crankcase.
Regards, David
__________________ David Yerkes 1987 911 Targa - GP White |
I added about a quart of oil today, and while the drop is still there when removing the cap, it is less pronounced than before I added the oil. Is this 'normal' too?
i hope you checked the oil per the proper procedure .. fully warmed up on level ground.. all that said id stop analyzing all this minutia and just go drive the thing..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
At running temp keep the oil level @ HALF WAY or less on the dipstick. this will allow for oil expansion and prevent unnecessary oil consumption.
Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
THIS! Engine at full temp, and the front cooler feeling hot, level ground, at idle wait a full minute, then get the oil level right between the two marks. The temp is very important. Don’t even bother to check if the engine is not fully warmed up.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Trick is to just learn your car , and understand what the oil level will look like at 170 degrees in January in North Dakota or Canada vs 200 in Florida or California .. its pattern recognition that is important... just my 2c.
I agree with you this time........
With the engine cold, if I see oil on the end of the dip stick/s (engine not running), I know I have sufficient oil in my cars (911). That’s good enough for me to drive the car out for a drive. On my return home, a second check would show the oil level between the lower and upper markers. Then add oil as needed. Tony |
