FP picture, 3 questions
Should I replace the FP based on looks alone? Is this the original FP? AFAIK it works ok but looks like it could croak at any moment.
What is the flying saucer? Alarm horn?
Flying saucer wire disconnected.
What are the red pieces under the steering rack? You can also see them in the second picture above. They do not look to be original.
Old 10-18-2020, 12:39 PM
The spacers look like a bump steer kit usually fitted when you lower the front end below standard. Your fuel pump doesn’t look like it is properly mounted, which I would look at. If you’re happy to spend the money it won’t do any harm replacing the pump
Old 10-18-2020, 12:59 PM
Funny. I lowered the front end a few weeks ago to make the car look better. Odd that a PO put in a bumpsteer kit and then did not lower the front.
Is there supposed to be a bracket for the FP? Mine looks like it is attached with a hardware store band clamp and zip ties. I will do some research. Anyone got a photo of a properly mounted FP?
Thanks for your reply.
Old 10-18-2020, 02:19 PM
HarryD's Avatar
What year is the car? It looks like the fuel pump may have been relocated to the front. Not a bad thing. If it is working I would leave it alone.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-18-2020, 04:13 PM
yes, flying saucer is the alarm
Old 10-18-2020, 06:50 PM
It’s an 83SC Cab
Old 10-18-2020, 07:46 PM
Interesting. I have been through the car extensively and this is the first Ive known
that there was an alarm on it at one time.
Can you tell if this is the factory alarm horn or an aftermarket?
Old 10-18-2020, 07:49 PM
donbecker1234's Avatar
If you haven’t already, pull the fuel filter and use tin snips to cut it open to check for rust. Then pull the gas tank sender to look inside for rust.
For the alarm, check drivers door for a key slot.
I would just replace that pump on sight alone, but I just finished replacing every fuel line on my car. Welcome to the club.
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine
Old 10-18-2020, 08:30 PM
Items 22-30 are what you need to correctly mount the pump, it’s bolted through the aluminium cross-member in your picture and has rubber mounts. Maybe the car was lowered previously and a subsequent owner raised 5he suspension and didn’t know to remove the spacers?
Old 10-19-2020, 04:45 AM
Thanks Ian. Just now ordered new FP, bracket, mounts, check valve and fuel filter. The fuel lines look ok from underneath but I will check those as well on disassembly.
Hate to replace the FF already as its probably got only 500 miles on it but I read it was the best to do it with a FP change. I will keep it as a spare. Looks like a fun day project.
Old 10-19-2020, 09:42 AM
No key slot.
Agreed. A pump that looks like that is begging to be changed. Parts on order.
Old 10-19-2020, 09:46 AM
3rd_gear_Ted's Avatar
Not sure of the micron rating of the internal tank filter element, but a common mod is to add a micron rated fuel filter between the pump inlet and tank outlet.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 10-19-2020, 09:55 AM
When I got the car a year ago one thing I noticed was that the battery or previous one had leaked pretty badly. Cleaned all that up, new battery etc. Now looking at the FP (see picture above and below) I wonder if some of that got into the FP compartment. I had to dremel cut the very corroded clamp off because the screw mechanism had disintegrated. Notice one of the bracket mounts was shot. Glad I had ordered new ones from PP already.
Cleaned up the FP crevise, new bracket and mounts:
Looking much better. A new cap nut would look nice but no one sees it anyway.
New pump hums nicely, car runs good!
Thanks for the help guys.
Old 10-26-2020, 08:37 PM
Good job, ready for the next thirty years!
Old 10-27-2020, 12:19 AM
It looks like the factory alarm and is in the right locvation. Check the rear top edge of the driver door for the alarm switch
Old 10-27-2020, 06:09 PM
No switch or key slot.
Old 10-27-2020, 08:00 PM
