Can I run with only 5 fan pulley spacers temporarily?
In 101 Projects, Wayne says to make sure there are always 6 spacers. I just pulled the fan belt to replace it and only count 5. Can I run it like this for a couple days, only using 5, or is 6 that critical??
(anyone in the Phoenix area have a spare?) Thanks Mark
Mark - New Glarus, WI |
Mark,
Edit! I just talked with a mechanic friend and it looks like I was wrong about the shims. You must have all six shims installed to keep the proper clamping load on the alternator. It is possible to tighten down the alternator nut and have it contact the key on the shaft and not realize the pulley halves are not actually properly tightened. Rahl Quote from Grady Clay: You should keep the shims between the pulley half and the fan in perfect condition. They determine the tension in the belt and control the runout in the outer pulley half. As said above, the outer shims are just storage and prevent the nut/cup washer from running out of threads on the alternator shaft. But, Grady goes on to say... The cup shaped washer commonly becomes deformed with the center pushed in toward the fan. This has the same effect as running less than six total shims. The nut bottoms out at the end of the threads on the alternator shaft. The result is the nut is tight but not clamping the pulley halves together. The outer half is loose (or at least not clamped tightly) and everything gets ruined. Replace the cup washer if deformed at all. It is cheap compared to the alternative. So I guess it depends on how confident you are that you have enough threads and clearance to clamp the pulley properly. Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! Last edited by 356911930; 10-19-2020 at 10:03 AM.. |
Thanks. I was able to get the belt tensioned correctly with 4 on the inside and 1 on the outside, and the threads seem fine - thanks for the tip. I'll pick up another from the dealer Monday.
Yes, you can.
If you think about it, the ones on the outside don't do anything. They are just stored there under the cup Only the inside ones matter for pulley spacing
1986 Bosch Icon Wipers coupe. |
Racer
Wow. The “ones on the outside” do indeed do something.
Read what Grady Clay has to say in this thread: Pulley Shims, Wrong Config?
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
[QUOTE=winders;11068863]Wow. The “ones on the outside” do indeed do something.
Read what Grady Clay has to say in this thread: yup,simple as this;-) Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I don't think I've ever taken one apart that had the correct number of shims, happen to anyone else?
So based on that, yea you're fine. |
When I took my 3.0 apart there was only 5, so I ordered
Another shim from pelican in case I would need it for the Assembly. |
Why don't you read the link you posted and tell us what the shims on the outside do? They do nothing.
Jason
'79 911SC Targa |
The threads of the shaft run all the way to the base. The cup washer's height is higher than the depth of the alignment block notch. It is impossible to run of of threads. Anyone who has replaced a fan belt knows the shims on the outside do nothing.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-18-2020 at 03:02 PM.. |
1988 Carrera
Order several. Nothing like having one drop into the bottom of the engine while changing the belt road side. Keep the extras in the glove box. Or carry a magnet to fish it out.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Racer
But no, they don't do anything.....
Scott... do not bother dude;-))))
Ivan
I've seen several fans basically ruined for lack of the total stack thickness. You can get away with missing one or two for a short while, but the threads are not "full depth." Which means the outer pulley half will be a bit loose. Which means that over time the pulley half will wear a groove in the shaft, and eventually the shaft wont have its flat parts where they lock the half to the shaft and inner pulley part. Pictures of this can be found on Pelican, with guys wondering if it can be repaired.
This is not like some of the rather overblown nit picky stuff that gets discussed. |
Why would the nut need to be in the same place ? It makes zero difference where the nut is located on the threads. It's a nut and bolt. It just needs to be tight. You could extend the stud 6 feet and stack 500 washers and it wouldn't make any difference. The outer shims do nothing.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 10-18-2020 at 05:54 PM.. |
Wrong, the threads are full depth. Once the cup washer is on, it is impossible to run out of thread. Read post #11 again.
Q: Can I run with only 5 fan pulley spacers ?
A: Yes, you already are.
Racer
Oh brother....
What you have to worry about is the cup washer bottoming out on the fan center BEFORE it clamps the pulley half down against the fixed pulley half/spacers. Think about it.....
Saying stupid crap like "Oh, brother" does not make you any less wrong.
Yea, like I already said twice, that's physically impossible. Read post #11
