Safe way to raise front end?
Just want to raise front end to remove front wheels. A bit confused by what I've read on various threads. Is there a safe way to do it? I have a floor jack and jack stands.
Jason
'79 911SC Targa |
A search in this forum for the key words jacking point will turn up a bunch of threads.
Check this thread: Can you check my jack stand setup? Personally, I lift the side of the car at the factory jack point with a jack pad and trolley jack. To support the Front end of the car, I put the stands under the front end of the front torsion bar covers or at the pinch weld behind the wheel. I do one side at a time. For the tears I use the torsion bar covers or the torsion bar tube.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-19-2020 at 02:05 PM.. |
There are lots of opinions on this, many of which work and are safe.
I prefer to lift the rear of the car first, using a jack with a hockey puck on the engine case. Stay away from the sump plate. I place the jack stands on the tub, forward of the rear wheels. I then lift the front of the car using a piece of 2x4 to span between the front of the A-arms on the tub crossmember. I place the jack stands rear of the front wheels. I find this very safe and stable. |
I use two jack pads and two floor jacks. Just do a few pumps on each side at a time and lift the whole thing. Once up, you'll see that the jack points are like a pivot point on a teeter-totter. Front and rear are equally balanced. Use good jack stands once it's up.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
But this is your car. Do what you think is right.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-19-2020 at 05:25 PM.. |
Navin Johnson
OMFG!!!!
Seriously?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
[QUOTE=HarryD;11070711]Seems sketchy. Too unstable for me. Unless it is a two post lift, I like to see at least 3 points in contact with the ground at all times.
You may be missing the point.... once the car is raised, place the jack stands under the front or back or both depending on where you want to work. With the low clearance on these cars, it's the best technique I've found in 20 years of Porsche ownership.
Am thinking to jack up front using 2 x 4 as mentioned by Locker537. FWIW I have raised the rear in the past by placing floor jack under sump protected by wood block with cut-out for the plug. Thanks for your replies. Jason
'79 911SC Targa Last edited by LIRS6; 10-19-2020 at 06:01 PM.. |
Front and rear torsion bars are easy to find, no hoses or crease welds to deal with.
Been searching around. Is there a simple front point to jack the car up? ![]() If you buy one of those square bar round pad things to put in the square tubes in the side of the car near the Center of Mass you will find the whole side lifts up at one time. This allows for jack stand placement under torsion tube covers, but you end up going side to side in small increments. The "Y" at the top of a jack stand fits the curve of the torsions bars like they were made for each other. Might want to use small pieces of wood to crush for extra measure of anti-slip.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 10-19-2020 at 06:06 PM.. |
The first time I did it that way I did not have a cut out hole. Lucky for me I was using a piece of 2x6 cedar, a super soft wood that now has the perfect divot in it.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
[QUOTE=jlex;11070779]
Regards, Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 10-19-2020 at 08:20 PM.. Reason: added info |
I have a low profile jack and can barely get under the front torsion bars with thin 1x wood blocking on the jack pad.
How do you get under a 4x4 to lift up on the front torsion bars?
And, for the rear 2 wheels we do jack under the rear of the engine with a hockey puck - for the last 12 years of racing - no damage to engine . . . Also, we use a QuickJack in the garage for working on the car - dropping engine, brakes, suspension, etc. . . . Regards, Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 10-20-2020 at 07:34 AM.. Reason: added info |
Yes, clarification, when I say front torsion bar covers, I mean the hard point in the posted floor pan images (not the T-bars themselves) - see link provided for red car. I think it helps to keep all doors, hood and lid in closed position while jacking the body about. Once stabilized with multiple jacks and back ups, then openings can be opened with less fear of binding.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 10-20-2020 at 08:47 AM.. |
