walt's Avatar
Omega Spring Install
Replacing the omega spring and ran into a small problem trying to set the clutch arm into final position. The arm is hanging up on the small "L" bracket being held in with 2 small phillips screws. I've done this operation several times in the past and never had this issue. Hopefully one of you guys will see something obvious.
Walt
82SC 3.0
81SC 3.6
Old 10-21-2020, 02:41 PM
The spring is installed upside down, I don’t have a comparison
You need to load the spring arm before and cable before Installing the clutch lever
Bruce
Old 10-21-2020, 02:47 PM
proporsche's Avatar
how do you want to set in the final place if you do not have the cable hooked into the arm?
The spring`s what is supposed to stop on the L shaped bracket you are past that point.
.Remove the little finder with the spring(which is not correctly attached on the pic) then connect the clutch cable and pull back to its position with a bar
or big screwdriver.Only after you install the little finger and spring,adjust your clutch cable..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-21-2020, 03:01 PM
Not my photo, but I reference it often -
1978 SC Targa
Old 10-21-2020, 03:10 PM
walt's Avatar
Thanks I see it now. The original spring broke and didn't have a good point of reference. Working from memory doesn't always work for me.
Walt
82SC 3.0
81SC 3.6
Old 10-21-2020, 03:51 PM
MBAtarga's Avatar
Thanks - I've filed that image on my hard drive.
Mark
'83 SC Targa - since 5/5/2001
Old 10-21-2020, 04:06 PM
Walt Fricke's Avatar
Common mistake, and easy to make when you do this maybe once every 10 years, if that often.
Old 10-21-2020, 08:16 PM
