| Registered |
				Survey.  Engine rebuild and mileage.
			Some people insist that a 911 with 100k miles needs an engine rebuild. Let's collect some data. Has you car ever had an engine rebuild? or a top end? If not, what are your current total miles with no rebuild ?
				__________________ 1986 Bosch Icon Wipers coupe. | ||
|  10-31-2020, 05:51 AM |
| Retired, finally |
			AFAIK: no,no, and 240,000 miles
				__________________ 2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project | ||
|  10-31-2020, 05:52 AM |
| Registered Join Date: Aug 2010
			‘86 Carrera at 135,000 miles. Fried a crank bearing due to blocked oil feeder. Total rebuild to 3.4L. Much improved performance.
|  10-31-2020, 06:32 AM |
| Registered Join Date: Apr 2015
			87 3.2.  185k miles.  Front main seal leak meant it had to come apart to fix.
				__________________ Mark 1987 3.2 "Nancy's ride" ('cause Nancy owned it for 27 years before me) 1984 3.5 “Charley” (Charles owned it for 27 years) | ||
|  10-31-2020, 07:39 AM |
| Registered |
			'87 3.2, 147k, top end only, lots of oil past the valve guides
				__________________ '87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") | ||
|  10-31-2020, 07:53 AM |
| Registered |
			‘87 with 104k had top end with previous owner at 94k; currently undergoing a full year down at 104k prompted by broken head stud but decided to fully disassemble just to inspect to make sure bottom end was in good shape. Found that a couple other headstuds had already been replaced; intermediate shaft bearings pretty worn; rod and crank bearings were good but I will go ahead and replace since I am in this far. Also doing a few upgrades while I have it apart. I don’t think there is any magic potion. If you know the complete history and feel fully comfortable that it has received regular oil changes from the get go than you should go well in to the mid 100k, but you will likely have had a valve job prior to then.
				__________________ __________________ David Yerkes 1987 911 Targa - GP White | ||
|  10-31-2020, 08:38 AM |
| Registered Join Date: Oct 2008 Location: Denver, CO
				 | Quote:
 My 86 Carrera was doing this at 75k miles and a top-end teardown disclosed severely worn valve guides and cam lobes -- a top end rebuild completely resolved these issues and 100k miles post rebuild, I was still getting well over 2k miles per quart of oil. Understand this premature valve guide issue affects a disproportion share of '86 (and '85, or was it '87?) 3.2 engines, but that most are not affected. My situation could also have been accelerated/caused by its use as a daily driver in DC with hot weather/ac use/stop and go traffic. | ||
|  10-31-2020, 11:59 AM |
| Call 911 |
			Performed a top-end overhaul at 113,000 miles on my '88 coupe in 2011.  Heads sent out to Anchor Atlantic for new guides, valves, seals, etc.  They did a beautiful job at a reasonable price. Installed 964 cams and new head studs while apart.  Did a careful assembly and engine has not leaked a drop of oil since. I was going through 1 quart of oil every 600 miles before the overhaul with some blue smoke in the exhaust after extended idling. Now engine consumes 1 quart every 2500 miles and exhaust is clear. I did not split the case as oil pressure was excellent, and no trace of filings on the mag plugs or in the oil filter. Closing in on 150,000 miles and engine continues to run perfectly. The experience in working on this beautiful engine was well worth the effort.
				__________________ Dave Kirk My Porsche restoreth my soul. | ||
|  10-31-2020, 12:38 PM |
| Registered Join Date: Jun 2004 Location: Oxford, Ct.
			The experience in working on this beautiful engine was well worth the effort. +911 They are special!
				__________________ 07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com | ||
|  10-31-2020, 01:20 PM |
| Registered |
			resealed back in 2009  ,still original piston and cylinders...today mileage is in my signature
				__________________ 1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. | ||
|  10-31-2020, 01:38 PM |
| Registered |
			'80 Targa SC, complete overhaul at 136k miles. During 2019. Top-end was necessary - broken Dilavar head studs. Bottom end  - for safety.
				__________________ Petr ~ 80' Euro Copper Brown Metalic 911 SC Targa - New for me 89' Alfa Romeo GTV V6 2.0 TB | ||
|  10-31-2020, 02:14 PM |
| Free minder |
			The problem is that head-studs are usually broken at 100k miles if they haven’t been done before, and then since the engine is out it is a good time the refresh the top end. And sometimes the bottom  end too (slippery slope).
				__________________ 1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) | ||
|  10-31-2020, 02:34 PM |
| Registered |
			173,000 never been opened up, crossing fingers
|  10-31-2020, 02:46 PM |
| Registered Join Date: Nov 2009 Location: Waynesboro, Virginia
				67,100 miles
			My 84 had a broken cylinder head stud, so we pulled engine, freshened up heads, all new seals, and any kind of service item such as fuel injector rebuild. At 67,000 miles, the wear on the cylinders and internals was imperceptible. Everything looked perfect inside. It was a lovely thing to see and it made a believer out of me that these engines can go a quarter million miles and still be doing fine. On the other hand the broken stud was a bit horrifying.    | ||
|  10-31-2020, 03:55 PM |
| Registered Join Date: Jul 2001 Location: Lawrenceville GA 30045
			'83, 119k never opened.
				__________________ Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? | ||
|  10-31-2020, 06:06 PM |
| Rodek |
			My '78 is currently getting a top end rebuild. 151,000 miles.
				__________________ 1978 911 SC | ||
|  10-31-2020, 06:31 PM |
| Registered |
			At 85,000 top end.   140,000 complete  1970 T
|  10-31-2020, 06:32 PM |
| Registered Join Date: Oct 2014
			1983 SC  158,000 miles.  Broken head studs no real oil consumption.  As long as we had it apart did the top end.  Ended up getting an unexpected income tax return said what the heck spit the cases and do the bottom end.  Have had the car 25 years will out last me now.
|  11-01-2020, 12:44 AM |
| 1988 Carrera |
			My 88' was burning oil, due to valve guides .  Puller the engine for a top end job.  New guides, all valves, rings,studs and chains with sprockets at 120,000 miles.
				__________________ 88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too | ||
|  11-01-2020, 03:48 AM |
| Registered |
			Did a top end on my 85 at 162K miles in Oct 2012.  Had messed up the threads on my #6 by not tightening the sparkplug and then missing the torque.  Damn! I was burning less than a qt of oil every 2K miles.  Not a leak yet and I have put over 40K since.
				__________________ Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end | ||
|  11-01-2020, 11:42 AM |
