Can I use Curil-T on shift fork plate gasket?
My 85 carrera's transmission is leaking from the lower shift plate (I believe that's what it's called). I'm going to change out the gasket -- I purchased some Curil-T for another project. Can/should I use that on the gasket for the shift plate cover?
Probably a silly question, but I don't think I ever used any kind of sealer on that plate when I did it last - just thought I'd go the extra mile if it's worth it and put some sealer on there as well. Thanks Mark
Mark - New Glarus, WI |
yup, good idea;-)just not too much of it...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Goobery sealers on thin paper gaskets often cause the gasket to split and sqeeze out upon tightening. I would use spray coppercoat and let it set up before tightening.
just wonder what is ..Goobery sealers..? john
Ivan
i used hylomar that i had left over from another project. holy crap does that stuff seal.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Did you use the tube, or did you use a spray?
Red Line Service
I like Curil T, sorry John. Hylomar is basically the same thing, non-curing sealent. Hylomar, British, Curil T German.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
i used the tube .. i did not find them the same product at all ( Hylomar and Curil T ) ... but ill defer to the professionals. i used the hylomar blue in a tube..
