I had a pro do mine in epoxy, and my concrete was in pretty bad shape. My townhome is nearly 40 years old, and the concrete had a few cracks, along with the moisture issues that go along with living in Houston. They spent the first day sanding, etching, sealing the cracks and applying a moisture barrier epoxy. The second day they laid the speckle flakes and the epoxy clearcoat. It has a lifetime warranty and I recall it was around $1,650. I'm extremely happy with it and wish I would have done it years ago. I got the vinyl baseboard molding from Home Depot and installed it myself, which took me a couple of hours.
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 11-11-2020, 08:54 PM
Armor Garage
Epoxy
Old 11-12-2020, 01:53 PM
Shaun @ Tru6's Avatar
Originally Posted by glerbone View Post
Hey Shaun.
I used a solid polyespartic Along with a UV top coat. Pretty durable from oils etc. Just don’t drag a Jack with metal wheels across it.
https://www.garagecoatings.com/company/5085-polyaspartic-2-gal.asp
I did my home shop with it.
2yrs and counting.
What an amazing shop! Will add the 5085 to the list, thanks for posting.
What roll-up door company did you use? Is it entirely weatherproof? So far in my research not all roll-up doors are created equal.
Tru6 Restoration & Design
Old 11-12-2020, 04:45 PM
HarryD's Avatar
Those are called coiling doors. They are typically more expensive than an overhead door. You can get them with insulation and windows as upgrades. Frees up your overhead space.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-12-2020, 07:59 PM
Mr.Anderson
Hey Shaun, the building was a STAR building (the manufacturer)
They provided the doors. I insulted the shop with R19.
Old 11-12-2020, 10:55 PM
OK, thanks on the roll-up door info guys, I found one company that I like and they will custom cut the width. I'll be doing R19 too and probably putting in a mini split for winter work.
Old 11-13-2020, 04:23 AM
Epoxy coating it's simply the best option for garages, it's super hard, easy to clean, easy to mantain, and really long lasting
I would definitely recommended it
Old 04-08-2021, 04:39 PM
