CV joint tabs
Hi,
I have removed my inboard CV joints on my 84 3.2 and there were not any tab washers on the bolts. Are these necessary? The parts manual says that 4 are required, is this one on outboard and one on inboard on each drive shaft? Thank you Last edited by chateau; 11-16-2020 at 09:38 AM.. |
abides.
Which part number are you referring to?
Graham 1984 Carrera Targa |
Grappler
I think the Op is referring to these> https://www.eeuroparts.com/Parts/192418/Axle-Bolt-Lock-Plate-Rear-91133219100/
I don't see them on Pelican. They are needed and take 3 per side. You also need schnoor washers and new bolts.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
The 8x50 bolts on an 84 do not require washers but are required to be 12.9 hardness
In the PET the locking plates are used on the 10x50 bolts on the 86 and later. Bruce Last edited by Flat6pac; 11-16-2020 at 06:07 PM.. |
Thank you for the info Bruce
