Red face cold start problem not resolved
1987 Carrera
With the engine totally cold, started the car. The engine starts right away but in a missing fashion for about 2 seconds and then goes to 1200 RPM...And does its routine going down to 900 as programmed. The funny thing is that if I start it again 5 or 6 hours later, it starts properly, no hesitation
I did remove the valve cover on the upper left side, there were a few smears of oil but the roker shafts seem to be at in their place, changed the gasket and secured the plugs wires with RSR hold downs.
Just installed a new fuel pump so it is not the check valve
Any thoughts??
Old 11-14-2020, 08:56 AM
Following
Old 11-15-2020, 07:06 AM
proporsche's Avatar
David you post is like guessing game.Not solved..what did you do to try to solve it , that would help to mention here,how about that?.... so people can actually follow....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-15-2020, 10:09 AM
problem with cold start
I did what was described and awaiting new wormer spark plugs non resistive to replace the current ones.
Other then that, I do not have any ideas of what to do next to resolve the cold start "missing" symptom...
It is not a big deal because it only lasts for 2-3 seconds...but it annoys me.
Old 11-16-2020, 10:40 AM
6 cylinder symphony
My cars did exactly what you described until the Idle Control Valve completely failed. Once replaced - problem solved. My guess is that your ICV is failing.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 11-16-2020, 02:44 PM
Does the Idle Control Valve control the bypass air, only when the engine is cold, or also when it is warm ?
Old 11-17-2020, 12:07 AM
From one PeterM to another Peter M!
ICV controls bypass air at all temperatures.
Old 11-17-2020, 01:24 AM
Many thanks Peter M - great name you have !
I will use that information in my own tread on idle issues
Old 11-17-2020, 02:51 AM
Diss Member
Quicksilver's Avatar
Please test things instead of replacing them. A fuel pressure meter hooked to the fuel rail would have saved the cost of a fuel pump.
Things to check at this point.
- ICV
- Idle position switch
- Cylinder head temp sensor
And doing the idle speed setting procedure would be good about now.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-17-2020, 03:05 AM
Reference and speed sensors could be starting to fail or covered with oil/dirt.
Old 11-17-2020, 07:08 AM
6 cylinder symphony
CHT sensor is a good one. I had changed mine a few years ago when it failed as well, so that's why I didn't bring it up.
It's not a hard fix - just a little tricky getting the socket on the sensor.
'84 3.2 Targa
'89 964 Coupe
Old 11-17-2020, 07:24 AM
kevbo's Avatar
Subscribed. Same symptoms except mine chokes and coughs for about 15 seconds before it revs up and down. Then like yours its fine. Even after sitting for hours.
I took it in for this. They did a smoke test on the vacuum line and replaced several hoses. Didn’t fix it....
Kevin
1986 Carrera Targa
Old 11-17-2020, 07:09 PM
kevbo's Avatar
Oh, forgot to mention that I get a nice bit of white smoke now that accompanies the choking. This is new too.
Kevin
1986 Carrera Targa
Old 11-18-2020, 03:22 AM
