915 Shifter Couplers
Any suggestions on which shifter coupler (WEVO or Stomski) will best improve the shifting of my 85 911 with a 915 5 speed transmission ?
Also, should I also replace the Motor and Transmission Mounts?
Thanks again for any advice, Ken
Old 07-23-2020, 07:28 PM
I put the Wevo in my '84...BUTTER! So easy and a great upgrade!
1984 Carrera Targa, Moss Green - Sold (biggest mistake)
2008 Carrera 4s, Macadamia (Brown)
Old 07-23-2020, 07:40 PM
AutoBahned
RWebb's Avatar
Stomski copied Wevo's design, which is really nothing more than a sized coupling joint used in many industrial applications
a search will be rewarding...
Old 07-23-2020, 07:50 PM
The stock coupler with black delrin round hole bushings installed, work just as nice as the fancy ones.
206 637 4071
Old 07-23-2020, 09:08 PM
midnight911's Avatar
john walker is my man
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-23-2020, 09:20 PM
Bill Douglas's Avatar
In the early days of my SC ownership I replaced the engine and transmission mounts - an easy job, and it hugely improved the gear shifting. I think the engine and transmission were moving a bit while under acceleration, then moved again as I put the clutch in to shift gear.
I used what were called Sport mounts. Slightly stiffer rubber I suspect.
Old 07-24-2020, 12:52 AM
Flojo's Avatar
If in doubt of wear-grade in parts influencing proper shifting, here's a to-do:
- replace lower ball joint bushing of shifter
- replace coupler bushings
- replace trans mounts (maybe engine mounts in the go as well)
- reajust, drive off like 1985 new from factory
the easy way to go one step further:
- get the spring from Karsten => THIS
- improve coupler to brass bushings or the WEVO PJS coupler
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 07-24-2020, 01:16 AM
I put the wevo in and it shifts beautifully now (had a recently redone standard coupler inbefore). Next : transmission mounts
I don’t believe there is much difference between the wevo and the stomski.
1985 Carrera 3.2
Old 07-24-2020, 03:52 AM
BER BER is offline
BER's Avatar
Porsche Crest
I have the Wevo Shift coupler and the Wevo engine/tranny mounts. Could not be more pleased with the feel and handling of a almost 37 year old 911. 😊
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 07-24-2020, 04:32 AM
Thanks for your replies.... Always appreciate the advice from this group.
WEVO Coupler, new shifter bushing, engine and transmission mount are in the plans. Any suggestions on Mounts.
Old 07-24-2020, 08:02 AM
Still here
pmax's Avatar
Good to know the stock coupler with this 10$ part will do the same while keeping the dampening rubber bushing in place. Adding it to the todo list the next time I have to adjust the linkage.
Old 07-24-2020, 11:17 AM
Thanks John, they are now on my shopping list.
Old 07-24-2020, 12:38 PM
AutoBahned
RWebb's Avatar
There are 4 levels of 'stiffness' for engine/tranny mounts. In addition, you can mix & match by puttng stiffer ones at the trans vs. engine
Blue Wevo - stiffest
Black Wevo
Cabriolet
Stock, non-cab mounts - least stiff
Avoid solid mounts.
Replace the stock mounts if a PO did not - as they are old and hard, brittle.
Old 07-24-2020, 12:57 PM
Travis Neff's Avatar
I did the brass coupler insert, replaces the factory plastic piece. Seems to work great
72 914-6 GT Conversion 2.7
82 911 SC Coupe
78 SC Targa Hotrod
Old 07-24-2020, 01:31 PM
Brew Master
cabmandone's Avatar
Same here. I actually rebuilt two couplers. One coupler has brass, the other delrin. I figured if I didn't like the feel of the brass bushings, I could easily swap out to the delrin, The delrin coupler is collecting dust in my loft.
FWIW, I've driven a car with a wevo coupler and the owner of that car drove mine. We both agreed that there was no difference in the feel of the shifts between the two.
Nick
Old 07-24-2020, 02:13 PM
I used the Stomski and am very happy with it.
The only thing I noticed is a bit of noise in gear at the shifter- sort of a buzzing kind of noise- might need a little adjustment so the lever isn’t tight against the housing, but haven’t investigated yet.
Rutager West
Old 07-24-2020, 04:37 PM
MichaelSJackson's Avatar
When I removed my original coupler, I was astonished how degraded the original bushing was. Replaced with a Wevo. Big improvement, but bailing wire might have been an improvement too.
However, it transmits a lot of transmission sounds into the cab. Clearly, need to finally get that trans overhaul and upgrade.
The original bushing provides an intentional oval movement, while the Wevo is very precise bearing movement. I've rebuilt my original coupler with the delrin bushing and want to compare the two (Wevo vs. delrin) once I put the trans back in.
Old 07-26-2020, 12:41 PM
Also used the Stomski coupler along with JWest's Rennshift and very happy with the combo.
Old 07-27-2020, 09:17 AM
Rescuer of old cars
Arne2's Avatar
When I bought my '84, the PO had installed a factory short-shift, the transmission had fresh synchros and sliders but shift quality was poor. I replaced the linkage bushings, upgraded the transmission mounts to the firmer sport/cabrio parts, removed the short-shift kit, added a Seine Gate shift kit and delrin bushings in the stock coupler. Car shifted great after that was done. My new '72 (also with fresh 915) isn't too bad, but I am still planning on delrin coupler bushings and the firmer transmission mounts. I can't see that either the Wevo or Stromski couplers could be much better than the delrin bushings.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 07-27-2020, 10:40 AM
Bragging rights is all.
206 637 4071
Old 07-27-2020, 03:19 PM
