Rtrorkt's Avatar
Exhaust Fumes
Getting exhaust smell when driving with the windows up. In AZ that doesn't happen all that often but when it does it is annoying. Pic shows situation. Could I have cut the exhaust tips too short and the air from under the car is pushing the fumes into the car?
Other ideas?
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 11-24-2020, 01:34 PM
The 9 Store
do you have heat exchangers?
All used parts sold as is.
Old 11-24-2020, 02:00 PM
Put on a catalytic converter and it will smell less. Roll up the windows and use the AC.
Yea, right.
Old 11-24-2020, 02:41 PM
New-ish 911SC Targa Owner
pampadori's Avatar
Yes. Add 2 or 3 inches to those tips and that will help.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 11-24-2020, 05:08 PM
Close your rear 1/4 windows, believe it, exhaust backwash.
Old 11-24-2020, 05:13 PM
It's a 914 ...
stownsen914's Avatar
As I suspect mestein is getting at, old/damaged heat exchangers can sometimes cause exhaust fumes to get in the passenger cabin. Watch out for CO if that's the case.
Old 11-24-2020, 05:32 PM
The 9 Store
Bingo. It's very common on the 914's that I play with. Plug one end and do a smoke test. CO will kill you.
Old 11-24-2020, 07:20 PM
Rtrorkt's Avatar
Thank you for all of the answers/suggestions. Bought the car in '11 in Petaluma with no heat exchangers. Took it back east in '13 and had them added, since I would need heat. So the units are not that old. I will of course check them. The issue really shows up with all windows up and the 1/4 windows closed. Rear deck is just held down with the rubber straps.
Will go for a little run today. Cool enough in AZ to have the windows up
Old 11-25-2020, 06:17 AM
The 9 Store
Are your heat exchangers new SSI’s or used steel ones.
Old 11-25-2020, 01:14 PM
gtc gtc is offline
abides.
gtc's Avatar
Does it happen when you are driving or stopped?
Do you have seals around the engine tin?
Graham
1984 Carrera Targa
Old 11-25-2020, 01:58 PM
Rtrorkt's Avatar
they are used steel. Stopped or driving. Moving along seems to make things better. Need to verify the compleleness of the tin seal
Old 11-26-2020, 07:02 AM
There is a rubber boot that goes between the nose of the transmission and the hole through the back of the tunnel where the shift rod goes through. If this is missing, dislodged, or torn, fumes can get into the cabin. Pop the cover over shift coupler and take a peek.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 11-26-2020, 11:11 AM
