bcgreen's Avatar
How can you tell if your 911 needs valve adj?
I am curious at what point do you know your Porsche needs a valve adjustment?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-19-2020, 08:18 AM
Look at your service intervals in the manual. Just guessing every 6000 miles.
Old 11-19-2020, 10:33 AM
bcgreen's Avatar
Just called a Porsche mechanic and he said 15K if not tracked. If tracked they will tighten up, if driven normally, every 15K they will loosen. I should be able to hear extra sounds from the engine as the valves get loose.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-19-2020, 10:53 AM
Reiver
Reiver's Avatar
^^^ yup, I do mine a bit earlier...10 to 12 k.... and often don't have to adjust all of them...some still fine.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-19-2020, 11:31 AM
proporsche's Avatar
tape the engine sound and we will tell you ..or i will;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-19-2020, 11:33 AM
sithot's Avatar
If the guides are worn you can adjust them till Hell freezes over and they won't stay adjusted.
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 11-20-2020, 05:36 AM
The easiest noise that gives it away sounds like a ticking from the valve train.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 11-20-2020, 07:05 AM
Ivan
I'd appreciate your opinion...sorry to hijack OP thread!
https://www.dropbox.com/s/0vn81ysuzpf9k3i/IMG_2252.MOV?dl=0
Thx.
Old 11-21-2020, 11:35 AM
proporsche's Avatar
litespeed..it is actually not bad to a person not familiar..I do can hear a little noise there mainly on left side.Maybe another 5k and then do the valve adjustment.
here is mine for comparison...mind you it just started and idle is a little higher;-)
Ivan
https://www.youtube.com/watch?v=Out_PKGkYYY
Old 11-21-2020, 12:43 PM
bcgreen's Avatar
Luckily mine does not make any extra noises and does sound smooth as much as a RS engine can be called smooth.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-21-2020, 12:57 PM
proporsche's Avatar
so, you just answered your post question;-) that is the point you want to reach;-)
Ivan
Old 11-21-2020, 01:06 PM
bcgreen's Avatar
Just wanted some external confirmation.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-21-2020, 01:13 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
They will not tick or make any noise if tight (wont seal or hold compression). A less then perfectly smooth idle is an indication. I do mine ever other oil change and there are usually a couple that need adjusting.
Chris
89 Carrera
73 E
Old 11-25-2020, 04:41 AM
Has anyone used the Snapgap valve adjustment tool?
Old 11-25-2020, 07:04 AM
lespaul's Avatar
I see a few responses talking about a ticking sound indicating the need for adjustment. While it is true that a ticking noise may indicate that the valve gap is too wide and needs adjustment, the regular interval valve adjustment at 15,000 miles is needed for the opposite reason. As valve seats wear over time, the valve sits deeper and the gap gets tighter and there will be less/no ticking. A too tight adjustment can cause a valve to burn and that is why valves should always be checked/adjusted at least every 15,000 miles.
If you rely on "no ticking" or "ticking" to tell you when you need adjustment, that may be a poor measure to go by. Certainly, for example, someone whose engine has gone 15,000 miles without a valve check and is relying on "ticking" to tell them when to adjust is playing with a time bomb. By the time the next 15,000 miles rolls around, the "quiet engine" may be an engine with burnt valves.
A ticking sound is the result of a poor (too wide) adjustment or, rarely, the jam nut may have loosened which allows the valve adjustment screw to unscrew and open the gap.
The proper adjustment is a 0.10 mm gap between the foot of the adjustment screw and the valve stem. The Porsche margin of tolerance on that adjustment is +/- 0.05 mm. Thus, an adjustment is acceptable anywhere between 0.05mm and 0.15 mm. That said, at the recommended gap of 0.10 mm, you should have little to no noticeable ticking.
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 11-26-2020, 10:59 AM
