Carby idle circuit questions
Ida40.
I have reversed the secondary Venturi to block it. Blocked the main jet Emulsion and air corrector out Idle scew is out. Idle jet holder out. If I blow down the emulsion and finger over the idle jet I get no air out for the idle screw hole. If this correct or not. I have airflow from the screw to the base of the carb outlet. Lyndon |
Fixed
