How to tell if solid or hollow spoke
I have turbo twist rims on my car, 18×8.5 and 18x10 and wanted to know if there's an easy way to tell if they're solid or hollow spoke. Thanks.
Yes there is an easy way. Feel the back of the spoke. If it is smooth, it is hollow spoke. If you feel trenches, it is solid. There are good photos in this link.
https://www.6speedonline.com/forums/wheels-tires/118502-hollow-vs-solid-spoke-wheels-help.html
1979 Porsche 911SC Targa 1996 Porsche 993 C4S 2005 Porsche 996 Turbo S 2020 BMW X3M Competition 2003 BMW M5 |
Awesome, thanks!
No problem. Found this photo on line as well.
An alternative way to do it: look at the wheel part number behind the spokes and check against the Porsche wheel list in
http://www.944racing.de/wheelweights.php
📸 https://www.instagram.com/porsche.tech 📸 |
Rescuer of old cars
And here I was going to suggest cutting one open with a hacksaw to check!
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
a.k.a. G-man
Shout into the valve stem.
If you hear an echo, they’re hollow.
Сидеть, ложь, Переворачиваться |
Genuine Hollow Spokes have these part numbers:
Ole Skool - wouldn't have it any other way |
Metal valve stems... Don't even need to bend over.
Location: behind the redwood curtain, (humboldt county) california
Weight difference?? Both Cast??
What is the difference??
Do both weigh the same?? Both Cast?? I can't imagine how they would forge a hollow spoke, unless seperately formed and welded?? curious, chris |
Not sure what the allure is, they're cast so aren't particularly strong. In theory you could probably forge, with limitations, a hollow spoke wheel. It would be tremendously expensive though. Last edited by FrenchToast; 11-29-2020 at 04:22 PM.. |
