How to tell if solid or hollow spoke
I have turbo twist rims on my car, 18×8.5 and 18x10 and wanted to know if there's an easy way to tell if they're solid or hollow spoke. Thanks.
Old 11-28-2020, 12:33 PM
autobonrun's Avatar
Yes there is an easy way. Feel the back of the spoke. If it is smooth, it is hollow spoke. If you feel trenches, it is solid. There are good photos in this link.
https://www.6speedonline.com/forums/wheels-tires/118502-hollow-vs-solid-spoke-wheels-help.html
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 11-28-2020, 04:44 PM
Awesome, thanks!
Old 11-28-2020, 04:51 PM
autobonrun's Avatar
Originally Posted by Thunderchief View Post
Awesome, thanks!
No problem. Found this photo on line as well.
2003 BMW M5
Old 11-28-2020, 04:55 PM
WP0ZZZ's Avatar
An alternative way to do it: look at the wheel part number behind the spokes and check against the Porsche wheel list in
http://www.944racing.de/wheelweights.php
📸 https://www.instagram.com/porsche.tech 📸
Old 11-28-2020, 05:58 PM
Rescuer of old cars
Arne2's Avatar
And here I was going to suggest cutting one open with a hacksaw to check!
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-28-2020, 06:43 PM
a.k.a. G-man
Geronimo '74's Avatar
Shout into the valve stem.
If you hear an echo, they’re hollow.
Old 11-29-2020, 01:54 AM
Genuine Hollow Spokes have these part numbers:
Old 11-29-2020, 05:13 AM
Competizione's Avatar
Metal valve stems... Don't even need to bend over.
Old 11-29-2020, 06:42 AM
Location: behind the redwood curtain, (humboldt county) california
Weight difference?? Both Cast??
What is the difference??
Do both weigh the same??
Both Cast?? I can't imagine how they would forge a hollow spoke, unless seperately formed and welded??
curious,
chris
Old 11-29-2020, 03:07 PM
FrenchToast's Avatar
curious,
chris
Both are cast, the hollow versions are lighter.
Not sure what the allure is, they're cast so aren't particularly strong.
In theory you could probably forge, with limitations, a hollow spoke wheel. It would be tremendously expensive though.
Old 11-29-2020, 04:13 PM
