Originally Posted by Locker537 View Post
The retaining tab is not notched in that picture.
berndtj said they have different tabs. I'm curious about those.
Exactly, when I got a closer look I thought I was seeing things. I kept looking for the slot in the tabs like every other brake setup I have ever seen. That's when the chorus of "Dear God, why?" started.
Old 11-04-2021, 08:45 AM
wrxnofx's Avatar
This only works in the rear.
The front line feeds *through* the mount on the strut and must be disconnected.
Yes, you're right. I had forgotten about the front being different. Thanks for clarifying!
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 11-05-2021, 05:19 AM
The clip on the inner fender is the U shaped removeable clip. The clip on the strut requires breaking the line to remove. Not very helpful for caliper movement.
1978 SC Targa
Old 11-05-2021, 08:23 AM
berndtj's Avatar
So, I spoke too soon. I do have a removable clip which attaches to the body, but unfortunately I have a non removable clip on the strut.
I just did one of the front brakes today, and I removed the hard line going into the caliper.
Old 11-05-2021, 04:18 PM
Flojo's Avatar
Did that 2 winters ago when upgrading to 964 calipers.
Measured the needed length, chose the appropriate fittings at both ends and ordered online with a manufacturer for hydraulic
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-08-2021, 01:39 AM
Looks look amazing. Love the work!
Old 11-08-2021, 09:06 AM
Thank you for sharing this. Is this part list for a turbo car, or what model?
I am looking to do flexible front brake lines on my 88 M491 911 (turbo brake setup).
Or… can anyone verify the fittings needed on either end?
1) Fitting type at the caliper?
2) fitting type at hardline coming into wheel well? (10mm?)
Ideally I’d order lines assembled to the correct specs without adapters like I’ve done on other vehicles in the past.
Thanks!
Old 10-08-2025, 08:58 PM
Fittings should be the same. Inlet to turbo caliper is in different position than other calipers, so check the length of the flexible line.
Rick
1978 911SC
Old 10-09-2025, 02:32 AM
So for the front is it a 90 degree M10 male into the caliper, and a straight M10 female to connect to the factory hard line?
Old 10-09-2025, 07:43 AM
