Harnesses-What to buy?
I am in need of harnesses for DE events. What does everyone recommend? Are Crow harnesses as good as the others or is it necessary to spend more money? Thanks for the advice.
1986 944 Racecar
2000 Boxster ClubSport
Old 04-25-2013, 06:28 AM
ive used teh pyrotect 3 inch 5 point cam lock for years and years, they are great belts! nice and heavy, last a long time, great overall quality.
not the cheapest belts but you get what you pay for.
Old 04-25-2013, 06:31 AM
joe payne's Avatar
Years ago when I purchased a harness I asked the same question.
The answer was Schroth harness. The best and I never heard of them.
Now I see them in everything from Nascar to Formula 1.
jtp911
Old 04-25-2013, 08:39 AM
IROC's Avatar
I've had TRW/Sabelt camlocks and now have the G-Force camlocks. Both have been great, but I actually like the G-Force ones better (easier to adjust, etc).
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-25-2013, 08:49 AM
All the harnesses are essentially the same functionally, the difference between a $125 and a $300+ harness is whether the hardware is light and easy to use/adjust. Higher-end Schroth and Willans are probably your nicest options with everything else falling somewhere below for the most part.
Old 04-25-2013, 11:09 AM
Bill Verburg's Avatar
Assuming you have the correct seats w/ pass through holes
W/O Hans
Schroth Hybrid II or III
W/ Hans
Schroth Hybrid II Hans or III Hans
Bill Verburg
Old 04-25-2013, 11:35 AM
Thanks Bill. I am using a stock sport seat and Brey Krause harness bar and only doing DE events. Does that change your suggestion?
1986 944 Racecar
Old 04-26-2013, 02:52 PM
Undocumented User
McLaren-TAG's Avatar
I think it was in an tech inspection sheet where I saw it, but I know it's highly discouraged (if not illegal) to have a harness with a seat that does not have the pass through holes. There is nothing keeping them from sliding around the seat and being essentially useless.
Old 04-26-2013, 03:01 PM
yes, you don't use 5-6 pt harnesses w/o proper seats. The harnesses have to go through the side, back and seat holes to work right.
There are what are called 'tuning harnesses' that are designed for use w/ stock seats
Bill Verburg
Old 04-26-2013, 03:32 PM
OK....great information and this is why I ask! I am now in the market for a proper seat. I assume the same goes ofr the right seat for the instructor? Thanks again.
1986 944 Racecar
Old 04-26-2013, 07:06 PM
Northern Motorhead
wildcat077's Avatar
Most regions require equal restraints for the driver and passenger (instructor) although you might get away with it for the first event.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-26-2013, 08:50 PM
Senior Advisor
James Brown's Avatar
check your regional DE rules, you most of the time will be ok with stock belts/seats but if you want a harness (properly mounted), you need the proper seat and for me a hans device. Helmet that is SA rated, fire suit. Oh, then you add roll cage, fuel cell, fire system, lighter car parts........it never ends
08 Cayenne Turbo
Old 04-26-2013, 11:22 PM
Mr. Merk's Avatar
What is the current harness to use with stock seats?
I have a rollbar without a harness bar. What kind of hardware would I need?
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 12-10-2020, 10:10 AM
