Finally an update.... Sorry these are taking so long. Seems like it takes forever to get parts these days and I've been busier than expected with other gauges recently. I still have to wire up the lights and do final testing and assembly on these first 3, but there is a light at the end of the tunnel
![]() As you can see, each one is made to order and all the parts are custom made depending on the configuration and movements. Once I get these first 3 out the door I'll probably start another small batch of them. ![]() ![]()
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Finally... The first one is done and almost ready to send to Jeff. Hope to have the other 2 done in the next couple days.
Brilliant!
'79 911SC Targa |
2 more just about ready to ship. This first batch of 3 took much longer than I anticipated and I'm looking at a couple changes to the design to make the assembly easier.
Burnin' Rubber
Dang these look amazing!
First triple gauge went out last week. These are proving to be very time consuming to build but we're making a few changes to the design which will hopefully reduce the time required to assemble them.
One more quad gauge shipped today and one more in progress. I'm going to take a few weeks to catch up then I'll consider building another small batch of these.
Coram Deo
Hey, that's mine! I will be camped at the post office until further notice.
Thanks for doing this. [Edit: post 1600!]
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Truly beautiful work. Any car would love one of your gauges.
'71 914-6 #0372 '17 Macan GTS |
Would love to have one of the quad gauges as above for my 930. Any idea if there’s a digital to analog signal converter for the AFR gauge?
Sent from my iPhone using Tapatalk |
Damn this is amazing! Any chance of a gauge for us 912E owners that would replace the leftmost gas gauge with gas + oil pressure + AFR?
'76 912E '73.5 911T '72 2002tii '88 M3 '17 Mini S |
No problem doing triple gauge with gas, oil pressure, and AFR
I’ve got the PLX device.
Do you have the older one in the metal box or the newer plastic one? They both have the 0-5V analog output but the older one is very slow. Do you have any AFR gauge in the car now?
I’ve got the new one in the plastic box. Also got their digital readout gauge but nowhere is really good to put it so it can be read at a glance.
I’ve got a 935 boost gauge in the clock position and that stays. I don’t really need the voltage gauge so perhaps that’s cheaper. PM me prices if that’s best. Do you require my original gauge? Sent from my iPhone using Tapatalk |
Here's a 904 "style" triple gauge I'm finishing up. I was lucky to find a core 356 gauge on eBay so I used the 3 rounded lenses and the chrome center ring to build this gauge. These get expensive to build because you need that original 356 gauge plus all the other parts.
I'm working on a couple more combo gauges that should be finished up in the next couple weeks and I'm able to build a couple more before my son heads off to school. My son does all the CAD and machine work for the custom faces and parts that go into these gauges and he is heading back to school in a few weeks. So... if anyone is interested in a triple or quad gauge let me know in the next week or so and I'll have him make the necessary parts before he leaves. Next chance to order one will be over the Xmas holiday. There is a link at the top of the thread to request a quote. ![]()
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI Last edited by jbell959; 08-14-2021 at 08:39 AM.. |
This is going to be a stretch, but I'd like to investigate the possibility of a quad gauge as a replacement for my BMW 3.0CS clock. The stock left-most gauge on a CS is equivalent to the double-gauge for Porsche, as far as I can tell. As soon as I can get a measurement of the clock, I'll see what can work.
Example dual gauge: https://www.rogerstii.com/bmw-e9-3-0cs-instrument-cluster-fuel-temperature-gauge/
"Could be worse." "How?" "Could be raining." <proceeds to rain> 1994 540i modded to heck 1973 3.0 CS converted to 3.5L/Motronic/5 speed |
I'm working on trying to put 3 gauges in a small case but even to do that is proving to be challenging.
Thread Tools | |
Rate This Thread | |
