| Senior Member Join Date: Jan 2001
				What Are These Doing In My Garage !!!
			Hmmmmmm....... Attention, attention…………Project Alpha Twin Turbo commencing. Please stay tuned boys and girls…… | ||
|  04-25-2003, 06:17 PM |
| Registered |
			Very nice!  What happeded with the blower and the sequential shifiter?  It's been a long time since IPP has been graced with the Beast.   For you new members, you MUST check out the "The Beast"
				__________________ .. | ||
|  04-25-2003, 06:23 PM |
| Registered Join Date: Dec 2001 Location: MA USA
			Bout freakin time you got rid of that silly super
				__________________ Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, | ||
|  04-25-2003, 06:24 PM |
| Registered Join Date: Oct 2000 Location: Nor-Cal
			Mark, are you building another car?  Or is this a cahnge to the current beast? Either way, COOL! | ||
|  04-25-2003, 07:13 PM |
| Registered Join Date: Nov 1999 Location: Montreal, Canada
			Awesome!  Are those k16's or k24's?
				__________________ Mike 03 996tt w/efr7163 89 Carerra 3.6 | ||
|  04-25-2003, 07:22 PM |
			All, Thanks.  Yes its been a while, I haven't been around for a long time.  I've been "infixiated" on other stuff.  Anyway, the above teaser is what I'm going to do to the Beast.  I'm taking the SC off and putting on the twin turbos.  Thanks for the welcome back.
|  04-25-2003, 07:29 PM |
			K16's, I might do the K24 compressor upgrade later.  The K16's flow enough for 500hp that'll be a good start.
|  04-25-2003, 07:40 PM |
| Registered Join Date: Feb 2001 Location: Ottawa
			Mark, Why are you dropping the supercharger? Are you just looking for a new project (I would understand that) or the supercharger configuration had problems?
				__________________ Tony '78 911SC with BITZRACING EFI conversion kit | ||
|  04-25-2003, 08:05 PM |
			I'm doing the twin turbo project for a couple of reasons actully.  I am "itchin" to do something else, espcially since I have a mill, TIG welder, etc. now.  And also cause I've always had a problem with the SC and I'm tired of screwing around with it.  Basically, any time you take your foot off the gas the motor will stall. I am the ONLY one that can drive my car without stalling it cause I have the technique down. I've tried tuning and adjusting everything to no avail. My theory has always been that there is too much volume between the throttle body and cylinders causing major variations on vacuum pulses and unsteadiness in the intake stream. The TB is trying to effect too much volume. Because its a positive displacement SC the TB has to be on the inlet side so the intake track consists of the sc, intercooler, piping, manifold. Recently, to test my theory I remounted the TB to the original location on the intake manifold…..after the SC. The motor purred like a kitten and idled rock steady, which I think proved my theory. However, because the TB was now after the SC I had tremendous boost spikes when the SC bypass valve closed on partial throttle applications. I had 15 lbs of boost at idle with the bypass closed. To try to solve the problem I installed a blow off valve, relief valve but neither could relieve the pressure fast enough, not to mention the positive displacement SC kept making boost, unlike a turbo on off-throttle states.   I'm also very curious to see how the twin turbos will compare to the SC.....OK, OK I give up, just call me an addict!
|  04-25-2003, 08:44 PM |
			Addict  . But so what. | ||
|  04-25-2003, 08:48 PM |
| Montana 911 |
			Mark...just spent 30 min checking out the Monster from start to finish (well kind)...GREAT STUFF!!!  I wish I had your skills, that is a very nice car.
				__________________ H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R | ||
|  04-25-2003, 09:11 PM |
| Registered Join Date: Jul 2000 Location: Agoura Hills, Ca.
			Cool to see you on a new project. Still,,,would have liked to see the SC work longterm. Good luck and post often (with pics). We admire your stills and tenacity. Cheers Mark
				__________________ '87 911 3.2ltr Cab. ROW (sold  ) '90 964 3.8 ltr C4 Coupe (P-Dealer built, track prep'd, sold  ) ) OMYG..I'm Porscheless | ||
|  04-26-2003, 08:37 AM |
| Registered Join Date: Jan 2003 Location: Shuswap Lake, British Columbia, Canada
			That's what I like about this site.  You surf here everyday and get to know whats going on in the community...... and then BAM!!! Something like this pops up and blows your mind!!!!!!!! "The Beast" is one awesome project and now twin turbos, too wild. Great job, keep it up, wish we were neighbours.
				__________________ Rob McKibbon, Shuswap Boy <>< To steal ideas from one person is plagiarism, to steal ideas from many is research. Currently researching ideas for my '74 911 Cabriolet | ||
|  04-26-2003, 01:49 PM |
| Administrator Join Date: Feb 2000 Location: Los Angeles
				__________________ Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 | ||
|  04-26-2003, 02:06 PM |
| Got Boost? |
			Natchamp, I am planning on doing a supercharge install on a Carrera 3.0 with 8.5:1 compression running about 6 psi and EFI. Am I going to face the same problem or is it that you are running very high boost for a SC?
				__________________ "The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- | ||
|  04-26-2003, 06:08 PM |
| one of gods prototypes | Quote:
  and that looks like fun, keep us posted
				__________________ Brought to you by Carl's Jr. | ||
|  04-26-2003, 06:52 PM |
			Jack, you're funny, you shall never bow down to anyone after what you have accomplished! Imonboost, I was running @10-12 lbs of boost but my problem is not related to boost. It's an intake volume issue. If you are runing a centrifical SC you should have no problem cause you can mount the TB in the appropriate location on the intake manifold, or as close to the cylinders as possible. If its a possitive displacement SC, I would be very interested to see how it works. I'm not saying it can't be done. Someone recently gave me very good idea that might solve the problem. The intake issue I have is only part of the reason why I'm doing the TT project. | ||
|  04-26-2003, 07:09 PM |
| Registered | Quote:
 I can't imagine letting anyone else drive it...That is truly a work of beauty!
				__________________ 1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast | ||
|  04-26-2003, 07:47 PM |
| Author of "101 Projects" |
			Mark's engine is featured on page 108 of the Engine Rebuild book.  Too bad the supercharger didn't work out - it made the engine somewhat unique.  I suspect it will begin to look more like Kaspar's engine on page 109... -Wayne
				__________________ Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports | ||
|  04-26-2003, 08:25 PM |
			Check this out, I was playing with my 3D drawing program trying to figure out the primaries I'm going to build.  It's a cool program because you can actually see what it will look like.       | ||
|  04-27-2003, 12:21 AM |
