RS carpet install
Thanks to RallyJon's page...
www.rallystuff.com/pcar_carpet.html ...I installed my RS carpet set. I used the AppBiz kit, it installs the same as the Original Fit. I didn't need some of the pieces, so I used the extra to cover the B pillar top to bottom and also the area behind and above the rear windows. Check out the before and after pics. Next up are the RSA door panels and home engineered 911R window system with stock glass. I'll get pics on those in a few weeks.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
Doing mine now
Thanks for the inspiration ! Looks great and i love that cage Cheers, Ed
87 Carrera Backdate |
drag racing the short bus
Beautiful work, Tod.
I'm in the process of stripping out my interior to be replaced with gray RS carpeting. I also have an Autopower roll bar going in. Question to you and Dutchie (and others, if possible): did you guys take out the trim over the wheel wells? I'm thinking I'll have to do that to fit in the roll bar. Tod, I can't tell if you did take out that trim over the wells - the photos are a little dark around that part of your interior. Thanks.
The Terror of Tiny Town |
DD74 yes i took the trim over the wheelwells off, i had to because my cage is welded there. I made some sidepanels that will find behind the cage. I dont have any pictures yet but will try to make them soon for you.
Cheers, Ed
The kits do come with perlon for the side and rear, but I kept the stock panels.
