Rouxzy's Avatar
Runs perfect than won't start
This has happened a couple of times in the past. The car starts and runs fine. Then for not apparent reason I go to start it and it won't start. I can hear the fuel pump so I'm getting fuel, but it just won't start. I replaced the CD unit this winter with an MSD and a new coil, but with the same results as last summer. Any suggestions?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 04-27-2003, 05:36 PM
I would put some gauges on the CIS and see if it is holding pressure. I would think it could be the check valve or the accumulator. Did you lift the air meter and hear the injectors squirt?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 04-27-2003, 06:23 PM
Rouxzy's Avatar
Thanks Blown,
I found the problem. I was getting fuel but no spark. I traced it back to where I used a spade connector to get power from my 3 pin plug for my old cd unit. I am now going over all connections and going to solder all connections.
Tom
Ferdinand Porsche
Old 04-29-2003, 06:41 PM
