Does your battery indicator light come on when turning car off?
Just curious, if your battery light (in the same cluster as the oil temp/oil pressure) come on as the car is turning off.
i.e. once the ignition is switched off, as the engine is shutting down, does the light come on?
1987 Porsche Carrera Coupe
Old 04-01-2023, 08:38 AM
Its the Alternator light.
I’d check the output condition of the battery, connections and it’s age. Might be that it’s time to replace it if over 4 yrs. old.
With engine running use a multimeter and reading should be better or close to 14v. With engine off anything less than 12.5 would indicate the battery is not able hold a charge.
Worse case is when engine is running, the alternator andd/ot regulator is failing or combo of all three, including the battery.
Old 04-01-2023, 11:10 AM
If the light stays on with the key off, the alt has a bad diode or 3.
206 637 4071
Old 04-01-2023, 02:44 PM
Sorry..to clarify..
I was referring to the quick second where the light comes on as the car is turning off.
https://youtu.be/Tc53duOahtM
Old 04-02-2023, 08:41 AM
Mine does this too, seems normal
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 04-02-2023, 01:51 PM
My other ride is a C-130J
RNajarian's Avatar
Mine also flashes on as I turn off the engine, maybe less than a second. Alternator is new so I assume it is normal.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-02-2023, 02:25 PM
Thank you!
Old 04-02-2023, 02:57 PM
