6 x 15 Fuch differences
I expect this will be easy for someone out there!
6 x 15 Fuchs - 911361020 (pre 73) & 911364020 (post 73 I assume). How are they different apart from # & is the offset different? Can the later wheels be fitted to a 69-73 narrow bodied 911? Thanks,
Kiwi Reg # 381 1959 356A Conv D 1967 912 1972 911S |
Actually the wheels changed from the "deep-dish" style 6" to the falt style in 1972. Im pretty sure the actual offset is the same so they will be interchangable.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
6x15 Same Offset
Early/DEEP 901.361.012.06 FLAT 911.361.020.00 Later/FLAT 911.361.020.10 Don't know date offhand Last edited by 69 Soft Targa; 04-28-2003 at 10:15 AM.. |
The early versions of the 6 x 15 used a three prong attached center cap. The later version used a flanged ring attached center cap. Not interchangeable
Kiwi/Gary
I've got some early (deep) ones (presumably '69) and some late ones (presumably '75) at home. The latter are on the '75, the former are in a pile but were on the '69. If you wanted to borrow one of the later ones to check (they have 215/60/15s on them), then no problem. But as these guys point out, they will definitely fit.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Thanks everyone,
Hi Cam - must see your car soon, Gary
Yes! That would be cool Gary.
I better get it WOF'ed - too busy at work - its dragging on for weeks too.
I had a pair of deep dish and flat style on F&R on 72, no difference in offset, both pair fit just fine.
Phil |
Freshly restored deep dish 6x15's - oooohhh aaahhhh ooohhh
'60 356 Roadster Race Car '67 911S Race Car PRC Toyo Spec 911 Race Car |
Thread Tools | |
Rate This Thread | |
