Dept store Quartermaster
lendaddy's Avatar
This goes on how then? Release fork.
I gotta admit that I just dont get it. The release fork fits into the groove on the T/O bearing right? When you mate the tranny to the engine how does the fork "slip" over the front of the T/O bearing and into its groove? I mean you cannot come in from the side with the fork so what am I missing?
Cornpoppin' Pony Soldier
Old 04-28-2003, 06:44 AM
Tim L's Avatar
As you mate the transmission to the engine you rotate the fork into position making sure it is in the grove. Re-check after it is mated
Tim
Old 04-28-2003, 07:35 AM
Super Moderator
cstreit's Avatar
There's a notch in the top of the trans housing that helps you. Once I get the engine onto the studs, I use a flashlight and a long screwdriver to guide the shift fork into the groove properly. Hard to do if you have CIS on... THere's also some room underneath to do that.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-28-2003, 07:46 AM
lendaddy's Avatar
I guess what you guys are saying is it will make sense when I put it together. This is a pull type clutch right?
Old 04-28-2003, 11:06 AM
