-   -   First Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/1083579-first-engine-drop.html)
$yncro 01-23-2021 03:20 PM
Air box is blown..u would invest on a new one
And install the pop off valve. Things are adding up
Fast.
$yncro 01-23-2021 03:23 PM
Looks like a blown air box. I would invest on a new one
Install pop off valve. Things are adding up fast.!
gomezoneill 01-24-2021 03:30 AM
Originally Posted by Funracer (Post 11193701)
This oil line on top of the left side tensioner cover looks like it has a cut and pinched line on it. Am I missing an oil line somewhere?
http://forums.pelicanparts.com/uploa...1611355166.jpg
Timing chain tensioner supply line.
Funracer 01-24-2021 05:56 AM
Was this original or part of an old carrera chain tensioner kit that was undone?
ADDvanced 01-24-2021 06:43 AM
Yeah that cut off line should be feeding your tensioners. Will be interesting to pull the timing chain covers and see what kind of trnsioenrs you have....
I’d fix your airbox. Bolts/nuts will make clamping force. For the epoxy make sure you get something that bonds to ABS.
This is just me but I can deal with total scatter. Tearing down cis is fine but just do on step at a time or you might lose parts.
boyt911sc 01-24-2021 07:18 AM
CIS troubleshooting.........
Originally Posted by Funracer (Post 11194984)
Pulled this off and the gasket was totally gone, a few flakes of it remaining. Would this have contributed to any idle issues?
http://forums.pelicanparts.com/uploa...1611446953.jpg
Neil,
Your major problem is the cracked air box. No wonder you were having so much problem in troubleshooting. How many times did I ask you to do a smoke test? Re-seal the are box using either bigger metal screws or nuts & bolts. And pressure test before installation.
The air flow unit’s gasket is primarily a dust shield. Even without a gasket, it would not affect your CIS. Why? The AFM is under atmosphere condition like the air filter. The gasket comes in different materials (foam, paper, or cork).
The oil line by cylinder 1-2-3 is for a Carrera hydraulic fed tensioners and was modified/cut to work with your engine. I don’t think you have a Carrera 3.2 tensioner installed now in your motor.
Could you post a picture of the 3-4-5 chain housing cover? You would need a lot of patience to get this motor cleaned up. Keep us posted.
Tony
Funracer 01-24-2021 08:08 AM
See pics below.
Planning to fix this airbox
Scatter is ok until it sits there for 6 months. That’s when I get into trouble.
Funracer 01-24-2021 08:15 AM
Originally Posted by boyt911sc (Post 11195559)
Neil,
Tony
Hi Tony. Of course I did smoke test 3 times with a smoke generator I bought just for this purpose. This crack is underneath the runners and either had a very small amount of smoke or I missed it which is as likely. When I pull my oil cap the rpm drops 50-75 as it should so not sure this is a big air leak. But of course I will fix it. What do you recommend JB Weld or something else?
Here are the pics you requested
http://forums.pelicanparts.com/uploa...1611508441.jpg
Thanks for any replies!
Funracer 01-24-2021 08:21 AM
PS Tony
You are right about patience needed. Good thing I am retired have plenty of time.
I will clean the engine as best I can to improve its appearance but not going to go crazy making it look new. I have a long list of items to check and/or repair and if I can clean up along the way so much the better. This will never be a show car.
Pressure washer supposed to be here tomorrow. We will see how it looks afterwards and go from there.
Funracer 01-24-2021 02:57 PM
Cleaned the air box today.
Put in flashlight in one of the intake ports opposite the seam crack.
http://forums.pelicanparts.com/uploa...1611532304.jpg
The crack is under the two lower openings in this picture. No light shows through.
The injector sleeves were a real mess. I believe a lot more air coming through each of them. I have new sleeve O rings.
Funracer 01-26-2021 09:52 AM
All pressure washed. Not as clean as I would like but as clean as I can get with a sprayer. An improvement for sure though.
http://forums.pelicanparts.com/uploa...1611687118.jpg
Funracer 01-26-2021 09:54 AM
http://forums.pelicanparts.com/uploa...1611687179.jpg
Found this on the ground after I cleaned up. Anyone recognize it? The washer may have just blown it out of a crevice on the motor somewhere. Looks like something from around the clutch arm.
Funracer 01-26-2021 10:08 AM
http://forums.pelicanparts.com/uploa...1611687469.jpg
Note the capped off oil line above the tensioner opening. I assume these are original tensioners not the upgraded Carrera version.
If that is so I will replace the oil line with the correct original version and order two tensioner rebuild kits and tensioner guard kit from PP. The Carrera tensioner kits are outside my budget unfortunately. Maybe next time.
Does this sound like a good plan?
ADDvanced 01-26-2021 01:38 PM
If they aren't in your budget, buy them with a credit card. If those mechanical ones fail, which they can, your engine is donezo and you're going to need to pull it all the way apart. Unfamiliar with tensioner guard... if that can prevent failure maybe that is a more cost effective way.
Good idea with new lines, they aren't too much $.
proporsche 01-26-2021 01:49 PM
the pin you found is from your rear decklid shock absorber(hood shock)..not to worry ...
Ivan
Funracer 01-26-2021 05:36 PM
Oil fed tensioner kit $1000. Tensioner guards are $10 per side. PP sells both.
Ivan
Thanks Ivan
Flojo 01-27-2021 05:01 AM
that's a securing pin for either hood/lid shocks or the door band to A-pillar
Flojo 01-27-2021 05:03 AM
[img]
rinse with brake cleaner quick, then go next level with baken oven cleaner and a brush to rub in a bit.
though follow application rules.
don't let it soak too long on bare cast Aluminium (20-30 minutues should do the job anyway).
Funracer 01-27-2021 06:57 AM
Did some looking around last night. The Porsche priced tensioner kit that I had seen originally is $1200 per side, so $2400 total. The Sebro kit on PP is about $900 total for both sides which is at least sort of reasonable in the Porsche world.
Any issues with the Sebro kit?
Funracer 01-27-2021 06:58 AM
Great idea with the baking soda. I will do that at some point.
Pedro '84 Coupe 01-27-2021 08:03 AM
Originally Posted by Funracer (Post 11194960)
Great news. Took the alternator out today, checked everything with a straight edge, no warping, no cracks, put it all back together works perfectly. My guess is when I pulled the cooling cone off the back of the alt it must have come forward just a bit enough to contact the shroud. That’s about $500 I don’t have to spend
That is good news!
I'm not familiar with the Sebro kit but here's a link for a used kit (no affiliation to seller): http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1084413-carrera-tensioner-upgrade-setup.html
Showdown 01-27-2021 08:13 AM
https://www.pelicanparts.com/More_Info/930105911912.htm?pn=930-105-911-912-INT
I just put these on my 77. $1500 for the pair.
proporsche 01-27-2021 09:36 AM
i wonder why is it so expensive if in Europe the whole kit costs 620 Euros??
Funracer, stick with your stuff .............
Ivan
Funracer 01-27-2021 11:32 AM
Originally Posted by Showdown (Post 11199788)
That kit does both sides for $735 doesn’t it?
Funracer 01-28-2021 08:26 AM
Originally Posted by Pedro '84 Coupe (Post 11199762)
That is good news!
Purchased this today. Funny I check the parts for sale section every day and missed that. A few of the bits are missing from what he has for sale but all of those look to be available on PP.
I know I am taking a risk buying used but these are original Porsche parts and according to most people the failure rate on these tensioners is extremely small.
Thanks again for the tip!
Funracer 01-28-2021 08:31 AM
http://forums.pelicanparts.com/uploa...1611854954.jpg
Ready to move to the engine stand.
Seems most people mount these on the passenger (right) side. Any down side to mounting on the drivers (left) side? I want to get at my oil cooler this will give me more room on that side.
proporsche 01-28-2021 08:34 AM
remove the clutch..no need to have it on...
Ivan
Funracer 01-28-2021 08:58 AM
Ivan
Afraid to! Never done it!
911SauCy 01-28-2021 09:33 AM
Removes entire drive train from a vintage 911...
...deal breaker is clutch removal....
I'm dying...LOLOL
http://forums.pelicanparts.com/support/smileys/wat6.gif
Funracer 01-28-2021 10:39 AM
I'm dying...LOLOL
Well when you put it that way its pretty funny. Hate leaving my comfort zone!
I am leaving town tomorrow until Monday. Really want to get the motor on the stand before I go.
Can I mount the yolk on the drivers side and still remove the clutch while its on the stand next week? If not I guess it comes off today!
Funracer 01-28-2021 11:08 AM
http://forums.pelicanparts.com/uploa...1611864375.jpg
Eight came out no problem. The ninth one stripped inside the hex.
So not all that easy, unfortunately.
911 Rod 01-28-2021 11:41 AM
Man, you need better tools.
Are you using socket hex?
Funracer 01-28-2021 11:52 AM
It’s an Allen socket. May not have been pushed in all the way.
Drilled it out and banged a larger star socket and got it out.
http://forums.pelicanparts.com/uploa...1611866957.jpg
All 9 allen bolts are out. Pressure plate not moving. 101 Projects book says it should nearly fall off. That is not happening.
Can I put this on the engine stand with the yoke mounted on the drivers side and deal with it next week? I have to leave in an hour!
911 Rod 01-28-2021 12:06 PM
If my memory serves me correctly, (ya right) if you have the better Porsche yoke you can still take it off. Not so with the cheaper or VW yoke. Can't you tell by just doing a trial mount?
Funracer 01-28-2021 12:22 PM
Mine was bought from Fleabay. Had to remove the exhaust crossover tube and now it mounts flush to either side. If there is no reason not to I want to mount it to the drivers side so I will have more access to the oil cooler.
It’s the orange one a few pics up the thread on this page
proporsche 01-29-2021 12:53 AM
what exactly is your work plan on this engine?
Once you relocate the yoke ,prior that remove the flywheel ,you will be most likely replacing the seal behind it right?
Are you doing a valve job or ?.......?
Ivan
Flojo 01-29-2021 04:14 AM
removing the clutch is important at that stage to:
a) control the clutch (still good?)
b) inspect the flywheel
c) inspect the crank seal behind flywheel
Funracer 01-29-2021 05:41 AM
Ivan
My work plan is to inspect and repair/replace the following:
Drop and clean motor and engine compartment (done)
Engine to stand (not done yet)
Engine leak down and compression
Check head studs (already done this once but will retorque)
RSR seals (where to purchase these, I don’t think PP has them?)
ToD leaks
Return tubes replaced
Chain tensioners upgrade
Cam timing (not sure if this needs to be done)
Valves adjust with Snap Caps
Motor and Trans mounts
Injectors and sleeve O rings
Replace CSV O rings
Inspect airbox and CIS overall for air leaks and reseal (doing this now)
Oil cooler seals
Intake manifolds gaskets
Replace throttle plate bushings
Possibly have fuel distributor rebuilt
Possibly have fan/housing/strap refinished
Sound deadener replaced (done)
Inspect and lube dizzy
Lastly install all new exhaust
Generally to replace every seal, gasket and O ring that is accessible without opening the engine. Clutch was working well but since I have no maintenance history from the previous owner I will inspect and replace if necessary. I was unable to get the pressure plate off last night.
Not planning a valve job at the moment
I already have a large box of O rings and gaskets etc to get me going including shift shaft, flywheel and diff seals. Just need to get it on the stand and go go go!
I figure I will be done by next weekend! :)
Regards
Funracer 01-29-2021 05:46 AM
I will do this. I was hoping I could do it on the stand with the P201 style adapter I am using.
