Venetian's Avatar
Parking Lights-Drivers Side Out??
Both front and rear parking lights on drivers side are not working. Passengers side are fine. Not a bulb issue. For a short while the drivers headlight was out as well but it is working again on its own.
Any opinions? Thanks.
1987 Carrera, Venetian Blue.
Old 10-18-2011, 06:11 PM
Fuse, right and left side, different fuse. Listed inside the fuse cover.
Doug
Was 2.7racer.
'76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car.
'85 3.2 stock, Orient red, comfy street car.
Old 10-18-2011, 06:42 PM
COULD be contacts in the light housing. Put a volt meter or test light to it.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-18-2011, 06:44 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I can't find my engine lid light on my 81. The wires that feed that light (flopping around in the engine compartment) touched ground and fried it's fuse that also feeds the parking lights on the driver's side.
Something similar is happening to you.
Old 10-18-2011, 06:55 PM
pete3799's Avatar
Rotate the fuse in the holder. Probably not making contact.
Pete
79 911SC RoW
Old 10-18-2011, 07:13 PM
Venetian's Avatar
Will check out fuses. I assumed that both sides would have a common fuse. Thx.
Old 10-18-2011, 07:17 PM
redstrosekNic's Avatar
+1 on checking the contacts. I recently had an issue of the brake lights dimming the tail lights when switched on. All of my goofy problems were the result of bad contacts within the light wiring harness.
Good luck!!!
Dustin
Old 10-18-2011, 07:28 PM
Wash. State
nesslar's Avatar
I had a contact issue (lamp) years ago, fixed it with some WD40, no problem since; same lamp and all. No visible corrosion was there, but it doesn't take much.
Old 10-18-2011, 07:32 PM
Targa Time's Avatar
I had the same problem. After much tracing it turned out to be the engine compartment light grounded out. It is on the same circuit as the left parking/turn signal lights. However I kept blowing fuses and you didn't mention that. Otherwise +1 on cleaning up the fuse contact points. Amazing how little corrosion it takes to loose contact.
Old 10-19-2011, 03:55 AM
dshepp806's Avatar
fuse/....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-19-2011, 04:30 AM
Is it your turn signal!? Some models were wired so that the parking lights would go on only on one side with the parking lights on, turn signal on and engine off- as a way of just having the 'traffic side' lights on to save the battery....
Old 10-26-2011, 10:17 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
+2 on the contacts. I had the same problem on my 81, and when I wiggled the rear bulb they all came on. cleaned them and fixed it. for the time being....
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 10-26-2011, 11:32 PM
Diode part # 911.617.108.00 under d/s dash burned out, euro park feature for t/s op of left frt and rear park lights w/key off. Simply remove diode and reconnect the male-female wire connectors. Ken
Old 10-27-2011, 02:49 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Parking light.
Assuming that the fuse is good, and you have voltage at the bottom of the designated fuse, your issue may be the engine compartment light housing.
The diode in the previous post controls the right side front and rear parking lights.
Upon failure, the right parking lights stay on due to a bypassed circuit.
I can post the circuit for the diode if anyone is interested.
Here's the CKT for the engine compartment light.
Hope this helps.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-27-2011, 04:38 PM
Peter Zimmermann's Avatar
I may be wrong (it's been a while!) but I think that diode is only on '86 cars, and only affects the right side parking lights.
Keep the Shiny Side UP!
Pete Z.
Old 10-27-2011, 04:45 PM
Your correct Pete, it's for the right park lights, (my bad memory) but I had a diode in my 88 930, also found them in 89 911's also. Ken
Old 10-28-2011, 02:29 PM
carreradpt's Avatar
Had the same problem. It was the engine compt light that I rewired incorrectly when I swapped my tailless deck as I recall. Drove me nuts.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 10-28-2011, 02:46 PM
Thank you to everyone on this thread.
My engine compartment light corroded and caused a short. The number 18 fuse popped knocking out the Front and left left driving lights and both of the rear driving lights.
I had trouble tracing it to the engine compartment light, even with a power probe. Gerry's brilliant post w/ diagram helped a tremendously. Gerry, where is that diagram from, Bentley Service Manual?
I want a full set of logical and physical wiring diagrams.
The bulb fixture body, which is also switch was corroded to positive grey wire making a short. I also did not know that the engine compartment light is on the same circuit the LEFT parking lights.
Thank to Pelican Parts for hosting this amazing site. I'm ordering a new engine compartment light now.
Old 01-22-2021, 10:17 PM
