Bilstein rollpin install help
I'm installing the roll pin on new Bilstein inserts.
- how do i know the shock insert is fully seated? (or is that a pointless question?) - More importantly, how do you drive it back in? Just line it up and tap with a hammer, or is there a better way? Thanks Mark
Mark - New Glarus, WI |
Stick a punch in the hole to line up the notch in the shaft with the hole. Leave the punch in while you drive the pin in from the other side. If you can pull the shock out while the punch is in, it's not down far enough. The split in the pin faces away from the shock shaft.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 01-23-2021 at 12:43 PM.. |
