77 Restorer
Triple Nut Exhaust/Sport header removal 1977 911
Hi all:
I'm in the midst of pulling apart my recently acquired '77 911 2.7l engine in order to fix the myriad of leaks and update. Upon looking at my heat exchanger-less exhaust, there aren't the usual nuts, but a pile of three (see figure). As is usual, I really want to avoid breaking studs, so I ask for the collective wisdom of the group - what's the best way to address this triple threat? One nut at a time after PB Blaster/Liquid Wrench?
Thanks,
Bert
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 01-21-2021, 06:54 PM
I believe you only have one nut, holding two larger nuts as spacers. After the end nut is off, the two spacer nuts will come right off. Rob
Old 01-21-2021, 07:26 PM
otto_kretschmer's Avatar
You have the long studs like I do. Just take the nuts off and be careful. I don't think you will have a problem. They look in better shape than mine are.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1080368-exhaust-studs.html
Old 01-21-2021, 10:46 PM
Originally, the 77 had thermal reactors. The thermals used long studs for thick flanges
The studs are narrower between the threads so don’t tighten to break loose.
Bruce
Old 01-22-2021, 03:23 AM
77 Restorer
Thanks - I will look more closely at all of these to see. Much appreciated!
Bert
Old 01-22-2021, 05:58 AM
77 Restorer
Thanks Otto - good to have your experience here. Thanks for the link to your post - I'm sorry I missed it; didn't come up on my search. Very helpful.
Bert
Old 01-22-2021, 05:59 AM
77 Restorer
Bruce
Thanks Bruce - as usual, your knowledge is incredibly helpful. My hope is the magic of penetrating fluid might be able to help me get these off with nary a broken stud (and no tightening to break loose!).
Bert
Old 01-22-2021, 06:01 AM
Good God. Now I have seen it all.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-22-2021, 08:02 AM
Just to confirm the basics, use a box wrench or 6 pt. socket to avoid rounding the hex corners. You might want to use another wrench on that "spacer" nut to provide additional structural support as you attempt removal. You want to take all steps to avoid breaking said stud.
Sherwood
Old 01-22-2021, 04:35 PM
77 Restorer
Sherwood
Thanks Sherwood - that's a great idea. I was going to use a T-wrench with a socket but that sounds like an excellent suggestion. Thanks again!
Bert
Old 01-22-2021, 05:33 PM
Since you will be sending the heads out for rework (guessing) I wouldn't sweat it if you break a few, just have your machine shop replace them.
May as well have them replace them all anyway to get to the length you want, based on what exhaust flange thickness you want to run going forward.
Old 01-23-2021, 07:51 AM
77 Restorer
Thanks. Want to thank everyone - was able to get the nuts off with PB Blaster persuasion and a box wrench without breaking a stud. Removed the headers, and now figuring out if I want to add heat back to the car since I'm not in SoCal anymore...
Bert
Old 01-24-2021, 03:40 PM
