Burint's Avatar
What's inside the megaphone?
Hello,
I found this photo of the megaphone insert piece and the article written about it.
http://www.early911sregistry.org/fo...p?t=6828&page=6
Really want to know.
-If every megaphone in the market have this insert piece?
-Where can I buy them?
-What's the pro and con of the megaphone?
Burint
Old 09-27-2006, 11:22 PM
randywebb's Avatar
search for:
Bill + Verburg + Archimedes + roll + over + in + his + grave
or who knows -- maybe it really does something re the pulse timing
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 09-27-2006, 11:30 PM
Zeke's Avatar
Those were supposedly on someone's desk. A hero engineer like Springer, I don't remember. There is no assertion that all megs had these corkscrews ahead of the cookie cutters. Seems to me that if they were after the swirling extracttion effect, they would have angled the cookie fins too. I think that is a device to provide some backpressure. I installed a completely different style of device ahead of my cookies for some backpressure and some quieting.
Old 09-28-2006, 07:44 AM
Paul Thomas's Avatar
That pic is of some inserts that Kurt Zimmerman had made for his "unobtanium" 917 megaphones. If i remember right, they are supposed to make them quieter without restricting flow to much.
Megaphone:
Pros- Its basically running straight pipes
Con- Its basically running straight pipes
Paul
My ignition is retarded.
Old 09-28-2006, 07:49 AM
Grady Clay's Avatar
I have never seen the screws on a Porsche megaphone. Every Porsche megaphone that I have seen (including 917s) just has the “cookie-cutter” diffuser.
As I understand Porsche exhaust; the reflected pulse is from the junction of the three-into-one. The end of the pipe is both a truncated megaphone and a diffuser in order to minimize the reflection from the pipe-end. The reason the cookie-cutter extends both into and out of the megaphone is to broaden the effect.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-28-2006, 08:04 AM
Burint's Avatar
Hi
Sorry for the wrong link at begining, try this one for details.
http://www.early911sregistry.org/forum/showthread.php?t=6828&page=4
Burint
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776
86, 930.
70, 3.2.
67, 911.
Old 09-28-2006, 08:31 AM
Burint's Avatar
Hi
Burint
86, 930.
70, 3.2.
67, 911.
Cool thread, thx for the link.
Old 09-28-2006, 09:02 AM
randywebb's Avatar
The best thing to do with a reflected pulse is to reflect it at an angle - hence the use of diverging/converging cones such as the Phase 9s.
Smith has a write up on them in his exhaust book -- it's not a new idea...
Old 09-28-2006, 11:22 AM
dtw dtw is offline
GAFB
The cookie cutter is to catch all them rods and valves n'piston crowns n'such, so's you don't break the windshield of the feller behind you.
Several BMWs
Old 09-28-2006, 11:31 AM
Location: behind the redwood curtain, (humboldt county) california
cookie cutter exhaust tips
Someone said the cookie cutter tips were developed to prevent the exhaust pipes from getting crushed shut, when running low on rough roads. ????????
Personally, i think they look very cool and they are one of the few things i might do, just for appearance - and in case i ever run fast over rough roads.
chris
Old 01-24-2021, 02:43 PM
Flojo's Avatar
regarding general weight savings in a race car, I see no point to add this weight.
change my mind.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 01-26-2021, 07:39 AM
