Alternatives for Clock and its location
Hi folks,
Wanted to get the collective's thoughts on alternative uses for the clock location in the cockpit. Would love to see what folks have replaced the clock with that could offer some function, data, etc? Looking forward to ideas, thanks! |
Mine just shipped and will be here this week. It matches the fuel quantity gauge on the opposite corner of the panel, but with Voltage/AFR
http://forums.pelicanparts.com/uploa...1611761867.jpg |
Also where are you tapping in for the AFR Sensor? The car has SSI Heat exchangers going into a Dansk 2 in 1 out, so there isn't a location where both the exhaust gases merge prior to the muffler. Thoughts? |
I guess I don’t have to post mine as katchi has it in post.
The picture is kinda dark, but I'm running an LED oil pressure idiot light around a voltmeter.
http://forums.pelicanparts.com/uploa...1599572546.jpg |
I like the fact that the voltmeter is VDO, although the AEM AFR gauge on the post above could also be a good option. Just need to learn where to tap the bung into to read the data on a car that has SSI Heat exchangers going into a 2 in 1 out Dansk. |
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1066760-clock-delete-w-gauge-led-oil-light.html The VDO gauge is from Amazon. I bought it almost entirely to double-check the cigarette lighter-to-USB thing I bought that has a digital voltmeter on it. The VDO unit reacts slower than the digital guy, but they're generally very close in readings. |
I installed the Perfect Tuning gauge. It is available with up to 4 sensors, has multiple display options and warning alarms.
Mine has AFR, Boost/Vac, fuel pressure and Volt. The fuel pressure and AFR made tuning nice. This is the post from my build thread. Quote:
If you have CIS a real time AFR will tell you how the system is working thru out the rpm range...volt meter is nice but not as critical by a long shot.
Car does have CIS. Great point. Sent from my iPhone |
The gauge he sent me looks like Porsche made it. Perfect. Good luck |
I have 2 of these, one works and the other needs to be rebuilt. I may move the clock to the in progress console.
Targahttp://forums.pelicanparts.com/uploa...1612156287.jpg JD '73 T Targa |
The clock from my 77 is in the clockshop. Got tired of the unwanted vent blowing in my face so I picked up a 90mm quartz clock insert and made my own face. Total of $9 invested.
http://forums.pelicanparts.com/uploa...1619393860.jpg http://forums.pelicanparts.com/uploa...1619393860.jpg http://forums.pelicanparts.com/uploa...1619393860.jpg |
I swapped out my clock for a afr, a cht, inj pulse, knock, ethanol content, ign timing, tps, map, fuel pressure, boost, lambda feedback, and probably a few others I'm forgetting gauge.
Rather, I installed a CANbus gauge. ;) https://youtu.be/ntQZF_mQ5YA |
This is freaking brilliant!! I found the clock on Amazon. Do you mind sharing where you found this template for the face? Thanks! $9 is awesome!! Sent from my iPhone |
*The secondhand takes some force to pull, careful not to bend it. You will also need to re-use the original gasket ontop of the included gasket to get it to fit, otherwise wrap it with weatherstripping to create a snug fit. |
<iframe width="560" height="315" src="https://www.youtube.com/embed/xTHFm7NVc04" frameborder="0" gesture="media" allow="encrypted-media" allowfullscreen></iframe>
This is a common modification for track cars. It's a generic trailer light wired via a relay to the oil pressure light. Just happens to fit the clock opening.
I'm building a new motor with a modern ECU that can trigger the light for multiple conditions, maybe even flash patterns to indicate the severity. http://forums.pelicanparts.com/uploa...1619539490.JPG http://forums.pelicanparts.com/uploa...1619539490.JPG |
Clock is of little use so it doesn't need to be front and center. Mine works and I want to keep it so put it in the console.
http://forums.pelicanparts.com/uploa...1619570884.jpg Important gauges go where the clock was. ;) http://forums.pelicanparts.com/uploa...1619571072.jpg |
Nice Brian! Lots of data, very cool! What’s this one between the 2 gauges? https://uploads.tapatalk-cdn.com/202...3012b275c5.jpg Sent from my iPhone |
| All times are GMT -8. The time now is 11:31 AM. |
