I wish there was a volt meter that replaced the clock that was not a retro fit - a gage that was truly the right size and matched the other stock instruments. I may give NHS a call and see what the damage would be to create one using my clock housing.
Anyone ever done this?
- A pile of British stuff - A growing pile of German stuff ... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....) |
RETIRED
Yup.....I did, years ago. I had Wesstach make me one. 1/3 the cost from NH Speedo. Does it match? Nope but close enuff.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 05-22-2015 at 08:52 AM.. |
Vintage Owner
There's the one I got from Amazon. Usually reads 14 volts after starting and then runs at ~13.5 volts while driving. Cheap and easy to read.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
I had a gage made from a clock core by BigMarkDesign a number of years ago. Happy with the way it turned out.
'72 911T '73 MGB (sold) '71 Alfa GTV (sold) |
Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
RETIRED
yep, there it is....too lazy to look or take another pic. Like $40 bucks.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
pictures
Here are pics of voltmeter in tach by N. Hollywood in my 70 and 88. Good info.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
The Amazon digital mentioned above says it will not fit in 911 lighter. Based on comments I assume that it actually does ??
1987 Carrera, Venetian Blue. |
Reiver
I use a lighter powered radar det. and that plug wouldn't work until I purchased a US replacement receptacle at my FLAPS for a few bucks and cut the back end off (1/2 in). Then slide that into place (nice tight fit) and you can use any US device.
De Oppresso Liber Strength and Honor 5th Legion |
http://forums.pelicanparts.com/uploads24/image1432299708.jpg
this one fits in my 73.5 lighter just fine. I get 13.87v from my charging system. Probably a bit of voltage drop because I did not solder the wiring output crimps from the alternator. Will be on my to-do list next time I'm in that area. |
RETIRED
911 cig ports are not the same as US ones. A charging port from Manny, Moe and Jack can be put into the circuit. IT will work with a plug in style volt meter. They just aren't that accurate or reliable.
Overvoltage is THE leading cause of Bosch CDI ignition box failures. It will burn up components and the PCB. Unfortunately, spikes are as bad as constant overvoltage.
I have seen dozens of boxes that failed that way, mostly 3-pin boxes. I guess the earlier regulators were less reliable and thus it's the 3-pin boxes up to '78 that get hit the hardest by this. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
That gauge looks great. What are you using as the sender for the fuel mixture gauge?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Still here
Amazon comments are right. It's a loose fit. Not sure it will stay under 'spirited driving' conditions ! Not sure the LED's serve any purpose other than displaying voltage levels. Last edited by pmax; 06-19-2015 at 10:13 AM.. |
Burnin' Rubber
DANGER! install volt meter now!!
![]() Installed this neat and vital Voltmeter and also added a dual USB port with a cover (each port running 2.1A for fast charging). Looks OEM and functions great. I believe my VR is starting to give up the ghost. I installed the voltmeter to audit fluctuations. I've got a car with flickering dash + headlights whilst not under load. Hmmmmmm, grounds, VR, alternator ... Last edited by Koizumi; 06-19-2015 at 10:20 AM.. |
Reiver
Numerous posts on this. Basically cut down (shorten) and insert a US cigar lighter receptacle in your German one...bang, works.
83 911 Production Cab #10
The digitsLED only shows the voltage, not sure what else could be expecting from a $12 item. The one on the edge show the charging state Red / Yellow / Green
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Cheers
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
70 911T Sold ![]() 84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Still here
"The INNOVA Battery and Charging System Monitor displays the condition of your battery and charging system instantly. It protects the engine computer and 12-volt accessories from damaging surges when jump starting or recharging." |
