Alternatives for Clock and its location
Hi folks,
Wanted to get the collective's thoughts on alternative uses for the clock location in the cockpit. Would love to see what folks have replaced the clock with that could offer some function, data, etc? Looking forward to ideas, thanks!
71 911S 3.6 Rosewood 82SC 92 964 ROW- Sold 97 993 Coupe- Sold |
One of the more interesting ones I've read about lately was a air fuel ratio mixture analog display (AFR gauge) that fit in the hole.
A navigation display would be cool, though I have never seen a round one before. I think someone made an air vent, ram air, maybe a track car? DANGER! install volt meter now!! DANGER! install volt meter now!! ![]() DANGER! install volt meter now!! ![]() ![]() Show me pics of volt gage install Show me pics of volt gage install ![]() ![]() Offsite article from Hagerty: Monitoring the air/fuel mixture with a UEGO sensor https://www.hagerty.com/media/maintenance-and-tech/monitoring-the-air-fuel-mixture-with-uego-sensor/ ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 01-27-2021 at 07:31 AM.. |
Mine just shipped and will be here this week. It matches the fuel quantity gauge on the opposite corner of the panel, but with Voltage/AFR
Also where are you tapping in for the AFR Sensor? The car has SSI Heat exchangers going into a Dansk 2 in 1 out, so there isn't a location where both the exhaust gases merge prior to the muffler. Thoughts?
RETIRED
I guess I don’t have to post mine as katchi has it in post.
scumbag
The picture is kinda dark, but I'm running an LED oil pressure idiot light around a voltmeter.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
I like the fact that the voltmeter is VDO, although the AEM AFR gauge on the post above could also be a good option. Just need to learn where to tap the bung into to read the data on a car that has SSI Heat exchangers going into a 2 in 1 out Dansk.
scumbag
Clock delete w/gauge and Led oil light The VDO gauge is from Amazon. I bought it almost entirely to double-check the cigarette lighter-to-USB thing I bought that has a digital voltmeter on it. The VDO unit reacts slower than the digital guy, but they're generally very close in readings.
I installed the Perfect Tuning gauge. It is available with up to 4 sensors, has multiple display options and warning alarms.
Mine has AFR, Boost/Vac, fuel pressure and Volt. The fuel pressure and AFR made tuning nice. This is the post from my build thread. Quote:
Derrick |
Great stuff here!!
83’ SC |
Reiver
If you have CIS a real time AFR will tell you how the system is working thru out the rpm range...volt meter is nice but not as critical by a long shot.
De Oppresso Liber Strength and Honor 5th Legion |
Car does have CIS. Great point. Sent from my iPhone
The gauge he sent me looks like Porsche made it. Perfect. Good luck |
I have 2 of these, one works and the other needs to be rebuilt. I may move the clock to the in progress console.
Targa ![]() JD '73 T Targa |
Wearing Pants
The clock from my 77 is in the clockshop. Got tired of the unwanted vent blowing in my face so I picked up a 90mm quartz clock insert and made my own face. Total of $9 invested.
New-ish 911SC Targa Owner
I swapped out my clock for a afr, a cht, inj pulse, knock, ethanol content, ign timing, tps, map, fuel pressure, boost, lambda feedback, and probably a few others I'm forgetting gauge.
Rather, I installed a CANbus gauge. ![]() https://youtu.be/ntQZF_mQ5YA
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
This is freaking brilliant!! I found the clock on Amazon. Do you mind sharing where you found this template for the face? Thanks! $9 is awesome!! Sent from my iPhone
Wearing Pants
*The secondhand takes some force to pull, careful not to bend it. You will also need to re-use the original gasket ontop of the included gasket to get it to fit, otherwise wrap it with weatherstripping to create a snug fit. Last edited by CatSkynr; 04-26-2021 at 05:04 PM.. |
