Carrera Tensioner Upgrade Upgrades!
I am accumulating parts to do the Carrera tensioner upgrade while my engine is out.
Now reading about two Carrera tensioner mods. Both have been out there for awhile and I want to check current thinking. First is the “Jerry Wood” sleeve mod. Still worth doing? Second involves adding a flow restrictor to each tensioner oil supply line. Should I? On the hydraulic tensioner subject, while I hold it should I be able to compress the tensioner piston a bit with my thumb? Thanks Last edited by Funracer; 02-05-2021 at 03:00 PM.. |
funracer,
I'm no expert, but I've had the "Jerry Woods" mod in mine for years. I like the safety knowing that the tensioner travel is limited. This mod will not allow you to use the grenade pins to hold the tensioner piston compressed, but I have not found that to be a problem. I just install them on the car using a large set of channel lock pliers. As long as there is no oil in the tensioners, you can depress the piston against the spring pretty easily. Once you add oil, and the check balls are working correctly, depressing the piston is hard - I've always needed some kind of mechanical advantage (I use the vise when working near the workbench, and the channel lock pliers mentioned earlier for installation).
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
The 9 Store
There are some threads on this site that talk about the flow restrictors. Seems to me that they are important but I'm no expert.
All used parts sold as is. |
Oil Cam Feed Restrictor
From Cam Pitting, Piston Oil Squirter Testing Without Splitting Case, Post 38.
Years ago Dieter's in San Diego did some testing with the factory restrictors the cam still gets enough oil. Sorry, I can't find this on the internet. |
Under the radar
Is there also a restrictor for the oil just going to the tensioner.? I have not heard of it. But it sounds like a good idea. There is a stream of oil that continually flows through and out of the tensioners. Seems like a waste to me.
Not really since you don't need to replace the restrictor when installing the tensioner upgrade kits. The upgrade kit came out before the intermediate piece (restrictor) was changed.
I did the Jerry Wood mod when I installed the carrera tensioner upgrade. I agree with the OP that it gives the extra peace of mind. I also put the restrictors but have not inspected the cams in a while so I won’t give an opinion as to whether it’s good or bad. Next engine drop I will take a good look.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
