kstylianos's Avatar
Send a message via Yahoo to kstylianos
Spring Plate Calculator - Questions
I'm planning on installing the spring plates tonight with new 28mm torsion bars, Neatrix bushing and Bilstein Sports. Trying to calculate the correct angle using Will's and Thoms calculator. I know the new Bilsteins will take time to settle to my desired 24.5 height, but want to make sure that I set the initial angle correct.
Here are my parameters:
Weight = 1160kg (it's an 82 SC Targa, correct?)
Static Plate Droop = 3.8 (This is default for Euro Height of 25, I'd like to go 24.5 the rear. Is there a 'better' figure here?)
Rear torsion bar size = 28mm
Weight Distribution = 40/60
Calculated Angle = 23-24 degrees unsprung
These look correct?
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-29-2003, 01:00 PM
Thumbs down
Wil's and Thom's calc. works great. Make sure to include the angle of your car on jack stands when you measure the spring plate angle.
Don't be surprised if your car is initially 1" too high. It takes several miles before it will settle all the way down.
Neil
'73 911S targa
Old 04-29-2003, 01:20 PM
kstylianos's Avatar
Thanks Neil,
I will take the rake into consideration when measuring the spring plate angle.
Just want to make sure I have the weight and static plate droop figures correct before I continue with the 23-24 angle calculation.
Charlie Stylianos
1982 SC Targa
Old 04-29-2003, 01:33 PM
Note that the 3.8" default value is a measurement when the car is back on the ground. If you want to target less than 25" rear fender height...and you seem to want 24.5...then plug-in a value 1/2" less than 3.8"....use 3.3" in the calculator. 1160 kg is 2552 lbs....don't know if this is correct, maybe it is. May 85 Carrera was "spot-on" duplicating it's published weight of 2760 lbs. I'm somewhat troubled that an SC and 3.2 Carrera should be *that* different in weight. You need to input accurate data to get good results from the calculator. I didn't run or recheck your numbers so I can't comment on whether it's correct. Should be simple enough however. Just be accurate with the input numbers, and all should be fine.
If your car had Bilsteins before...and now have new Bilsteins..then you should be OK. If your car had hydraulic shocks before..and now you have Bilsteins..then I would target a new free-hanging droop angle that is 1 degree more horizontal than the calculator suggests...to compensate for the tendency for high-pressure gas shocks like Bilsteins to raise the car somewhat.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-29-2003, 01:36 PM
OH...and you may want to adjust the two-piece spring plate to "mid-range"...so when you're all done, you have about a (+/-) 3/8" range of adjustment...for fine-tuning.
---Wil Ferch
Wil Ferch
Old 04-29-2003, 01:39 PM
From what source did you get your weight figure? You should find out what the car really weighs. From my experience, the number shown in the door jamb and owners manual seems to be a bit on the heavy side, so your car will end up higher than you want.
Old 04-29-2003, 01:41 PM
kstylianos's Avatar
Thanks Wil,
I had the standard Boge's before, thanks for the tip.
I'll use the 3.3" measurement and lookup the weight in the owners manual.
I should be good to go tonight.
-Charlie
Charlie Stylianos
1982 SC Targa
Old 04-29-2003, 01:44 PM
kstylianos's Avatar
Thom,
The car isnt at work so I used the Rennlist FAQ to find the weight.
Charlie Stylianos
1982 SC Targa
Old 04-29-2003, 01:46 PM
ckelly's Avatar
I just installed my 30's in the rear using this method. I used the weight published in the owners manual, plus myself, and some fuel. Spring angle came out to 21-22 degrees. I set the car on 4 jack stands, as level as I could using the door sill plate as a guide. Set the adj. bolts to midrange, and set the angle exactly at 21-22 degrees.
Worked perfect, right on the money, minor adjustments was all that was needed, no re-indexing......1st try.
Clay
'80 SC coupe
Old 04-29-2003, 02:45 PM
Ok, works for me. I actually went to the trouble of weighing mine.
Old 04-29-2003, 03:20 PM
kstylianos's Avatar
Just recalculated with:
Weight = 2756-lb (Owners Manual)
Static Plate Droop = 3.3 (taking into account 24.5 desired ride height)
Calculated Angle = 22-23 degrees unsprung
Shooting for 21-22 degrees due to the gas Bilsteins.
Probably will go with 22
Thanks again guys.....
Won't know how it really turns out until the engine goes back in and the Bilsteins settle.
-Charlie
Charlie Stylianos
1982 SC Targa
Old 04-29-2003, 05:20 PM
Let us know... Charlie....
Clay...it warms my heart to hear someone say it works the first time. That was the whole point of publishing this method in the first place, I was tired of hearing people say it may take 4-5 iterations to get right. All for a car platform that's been around for 30+ years..for goodness sake !!
---Wil Ferch
Wil Ferch
Old 04-30-2003, 01:54 PM
BTDT. I even broke my thumb dismembering a spring plate once.
Old 04-30-2003, 02:49 PM
Thom:
V. sorry to hear that...didn't know.
Pioneering has its drawbacks, eh?
---Wil
Wil Ferch
Old 05-01-2003, 08:10 AM
kstylianos's Avatar
Installed the swing arms and indexed the t-bars last night.
The rake, depending on the side I was working on, was between 3.5-4 degrees (nose down). I subtracted this from my desired angle and was able to set the bars spot on. I'll let you know what height it eventually settles down to.
Used this tool from the Home Depot:
Charlie Stylianos
1982 SC Targa
Old 05-01-2003, 08:22 AM
Certified Pre-Owned
BGCarrera32's Avatar
So where does one find the calculator???
'84 Carrera Coupe
Old 05-01-2003, 08:55 AM
kstylianos's Avatar
http://vintagebus.com/cgi-bin/spring.cgi
Charlie Stylianos
1982 SC Targa
Old 05-01-2003, 09:01 AM
Certified Pre-Owned
Dunka.
'84 Carrera Coupe
Old 05-01-2003, 09:03 AM
Craig Roche's Avatar
Charlie,
I was reading your thread and I'm curious to what your results were. I'm ready to install my springplates with Chucks bushings and revalved Bilstein Sports. Is it correct that if your cars sill is level then you just use the number the calculator gives, no adjustment? Did your allowance for the Bilsteins work out? Thanks!!
Craig
1984 911 Targa
Old 03-29-2004, 08:33 AM
