Try not, Do or Do not
Henry Schmidt's Avatar
High performance GT3 clutch
I'm in the process of upgrading my 996 GT3 to 3.8 and while the engine is out, I would like to install a new clutch. Street driving and carving corners on the occasional canyon runs is all I do.
Any thoughts on a nice clutch/flywheel upgrade?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-28-2021, 07:22 AM
Location: behind the redwood curtain, (humboldt county) california
Hi Henry,
I know this won't fit your engine, but i used a Kep all aluminum pressure plate, (about 6-1/2 pounds, I think it is rated for up to 400 hp), and a Fenlane 6+ pound RSR flywheel on my 74 915. These should liven p the engine a bit - perhaps they have something similar that would work on your G50???
chris
Old 02-28-2021, 08:11 AM
Hey Henry .
I have part numbers I can post tonight after I finish work , but you should look at the 4.0 lwf clutch .
If you want to go lighter there is a cup flywheel too , but probably not worth it on street driven car .
Old 02-28-2021, 09:12 AM
Bill Verburg's Avatar
996 GT3 RS
or
997 GT3 4.0 RS(will require a bit more leg for a bit more clamp)
Bill Verburg
Old 02-28-2021, 09:50 AM
Bill is right as usual 997 4.0 clutch and steel flywheel
Your car came with dual mass flywheel
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 02-28-2021, 10:05 AM
Full rs4.0 kit. Run it in my 964 and 997.1rs
The 40 pressure plate is a much stouter design.
Old 02-28-2021, 10:16 PM
Thanks for all the responses.
Henry Schmidt
Ph: 760-728-3062
Old 03-01-2021, 04:14 AM
