Where is the resistor pack?
My footwell fans have stopped working. The fans are good, just not getting 12v. Relay and fuse are good.
(It’s a 930 so there is not a fan/relay/fuse in the engine compartment. Thanks.
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
I think it's in the front trunk, right side, under the dash. Late 80s turbos had like 3 micro-switches in the auto-heat unit. Had to troubleshoot one once, total pain.
Thanks John. I guess you have to take the seats out to get to the automatic heater control unit, correct?
I know it’s kind of working because I can hear the solenoid moving the baffle cables. BTW, the heater control is $1600 new from Pelican.
Heat
This is the micro switch that was bad on mine sounds like it is the same problem i had.sorry can't upload pictures
Micro
Thanks, I may pull the seats and check those two switches. Or maybe I’ll just figure out a way to retrograde to the two little handles and a hi/lo fan switch.
