trick for 911 hood struts
Well I need some help here I have a 84 011 and I am trying to replace the hood struts. I may have done it 20 years ago. But for the life of my, I csn not remember how to un-do the drivers side strut. Ant tricks to it???
There is a chance I did not do it 20 years ago and just blew it off! Thanks for any advice
Steve Larson Dana Point, Ca 84 Cab, lots of TLC |
Umm, something like 20 years since I did mine too LOL
But I remember it was hard to get a (retaining?) clip on or off, so I tied some cotton to it so I could real in in from places unknown under the hood. |
I will be tackling this again soon. I remember long hemostats came in quite handy. Unfortunately I didn’t have access to a small child.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
'82 SC TL
Long needle nose pliers with an extendable magnet to keep clip from disappearing
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
I googled "911 hood strut trick" and found this thread and a few others Hood strut replacement tricks
To start with ..replace the pass..side so you do not have to hold the heavy hood with your shoulders.
Once you that one done clamp it with vice-grips just about before is fully extended. To remove the driver side is...i do no know what pin sefate clip do you have there.If already the new type--little plate clip ...remove it (again you have have it on the bottom pin) with a long flat screwdriver.Then lift the hood and with a L shape pick push the pin out( i do not know which direction in your case)....... Next..use long magnet to retrieve the pin or clip if you lost it there. Remove the upper pin and the hood-shock after--the hood should still stay up holding by the wisegrips on the other side. No make sure you align both ends on the NEW shock so they are facing the same direction(sometimes they are twisted) Insert the shock into position on the bottom and secure it on the top with the pin a safety clip After have flashlight or other light you have so you can see the bottom meeting place. Use long needle nose pliers and hold the pin .I usually insert them in from inside out towards the fender.No reason from the other side...unless you would like to curse for halve an hour... With the pin in your pliers lift the hood up and down a little bit so the pin goes in the holes. The trick is, i never put the securing pin`s clip on because it does not have to be there.The pin is on constant pressure and has no chance to go out or get loose. Just make sure the pin is in all the way Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I just did this job. Drivers side strut was a PITA, but a hemostat (with a bit of patience) ultimately worked for me.
My car's previous owner brazed a heavy wire across the back of the driver side pin. That provided a 4 inch handle. Still a PITA, because it doesn't want to slide through unless it is at the perfect angle.
Mine is starting to wear-out again and I keep deferring the fix. |
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
I stick a small blob of dum dum behind the pin head, just in case it wanders.
Kind of Blue
Hemostats are amazing for this job. I've only done them once and took me like a minute to do thanks to this trick.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Original Owner
Plenty of room to work on that driver side if you disconnect the hose clamp on the fuel filler tube (and the overflow hose)and then pull it back up a few inches by the neck. Two nuts under the filler flap as well.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
It's been along time since I replaced mine but I seem to recall tying a thin piece of string to it so it could be retrieved if dropped. Used dental floss I think.
Walt 82SC 3.0 81SC 3.6 |
After getting fed up with it, I offered $100 to a friend of mine to come do it, who then said she uses a 90 degree pick to hook the clip and pull it out, then uses a magnetic grabber tool to align it, then push it over the pin with a screwdriver. I'll still give her $100 to do it. Maybe I'll film it using the borescope and post it.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Kind of Blue
Rodek
My frunk lid gets opened frequently and as such the struts don't last as long. If you never want to change the hood struts again, do what I did and use these.
https://www.rennline.com/rennline-fully-mechanical-hood-strut-sku-e187/
1978 911 SC |
And whoever decided it should be placed on the outside of the strut on the fender side, instead of the inside, should be drawn and quartered.
Long nose pliers and a lot of I can do this
I was fortunate that my drivers side pin was already Out. Here are the tools I used and the only one that worked for getting the pin back in was the Magnetic Finger tip.
