Johnny new guy, and shifter bushing replacement
Sorry gang,
New guy here. Have not mastered how to search previous threads. But the one I saw on the topic did not hit head on to my struggle. What is the trick, clue, magic to insert a new shifter bushing into the shifter housing (1988 Porsche 911 cabriolet). The bushing the rod travels through to hook up to the shifter. I know it has to go through because there is a lip on the narrow end to hold it in once through the opening. But the diameter is just a tad bigger than the hole it goes through. Which makes obvious sense. Assistance would be appreciated. Best ![]() ![]()
In this link he suggests gently heating the bushing up. I'm waiting on parts to do the same job. Good luck.
https://www.hagerty.com/media/maintenance-and-tech/make-your-porsche-shifter-feel-like-new-in-one-weekend/ |
Here's some good info, I posted in the past. Post 14 of New shifter slop? Bushings gone?
G50 Rattle has a copy of the Excellence article Rattle Trap Simple repair and care of the 1984-89 911 shifter. |
Hook one side in and work the rest in with a slot screwdriver. Slot at the bottom, loop a long zip tie around the rod and lift up to get it started in the hole.
If the problem you're having is to get the shift rod through a new plastic bushing, I sympathize with you, having spent many hours trying to solve it myself. Finally i tried opening the "slot" just a tad by cutting away at the plastic bushing with an x-acto knife. It didn't take much work and didn't change the dimensions of the cutaway by much, but Presto!, everything fell together with ease, no problem.
![]() Yes, it's kludgey, but yes, it shifts beautifully once more (still have to wait patiently for 2nd gear). No problems so far after 10K miles.
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
Here is a good link that covers many of the challenges. Notice that the drawing is wrong, the notch should face down, not up, for part #12
Shifter bushing question
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Different on the 915, but I boiled the bushings in mine. You get really even heating on the bushing, it's fairly low temperature for the plastic, and you can handle the parts with some thin gloves.
