Analog Air Cooled
Idle fine, then drop so low it quits, then all is fine.
Was with friend picking up his 86 930. Drove 2 hrs home with no issues. We knew that there’s an issue with it loosing power on long shifts. Still no issues.
Get home, start it up again, and she revs erratic and such low idle it quits. Wait a few minutes, start up, she purrs idle for 3 mins ( 1.5-2 bar, 1100rpm ). Then out of nowhere, goes erratic and low to the point of cutting out. Not a turbo expert.. just a NA owner. Thoughts? Warm up reg?
86 Targa 91 964 13 6 SPD Cayenne |
Could be a lot of things. Suggest testing the fuel pressures to start, and record the outputs. There's a ton of great diagnostic guidance on the turbo forum if you do a search. Start with the easiest, which is putting a fuel pressure guage on the car and testing the specs against the book. Post the results in the turbo forum and you'll receive suggestions on next steps.
Analog Air Cooled
We have the book, so this is a great starting point.
Start with the easy stuff like finding vacuum leaks.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I would rather be driving
Check:
Fuel pumps (There are 2 on CIS 930) Check fuel pump relay - Do the mod to put single relay on each pump. Currently one relay driving 2 pumps Check fuel tank screen for debris - Clean/change as necessary Check fuel filter assembly. Check Control puressures Upgrade to Leask Adjustable WUR Setup Control pressures with new WUR Enjoy the boost.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I think you mean fuses they have to relays already.
You've got to start somewhere and all suggestions you receive will have merit. Be sure to keep a journal of what you're checking. I had chronic symptoms similar to yours but without a high idle. All CSI diagnostics were within spec, so I could put that aside as a likely culprit. I rewired the two fuel pump relays with separate fuseable links directly from the battery (as per the fix advocated by many on the turbo board) and resolved my issue for $7 in parts and 30 minutes of time. But...not before I sprung for a new rear fuel pump and rebuilt CDI. Sometimes you'll get lucky!
