Ordered the gauge kit online yesterday, should arrive before the weekend. Will keep you guys posted for sure.
Side question - where do you enter your signatures (and car stats) so they always appear at the bottom of your posts?
Old 03-30-2021, 01:40 PM
proporsche's Avatar
click on user pc left corner in light blue
1985 911 with original 502 191 miles...808 198 km
Old 03-30-2021, 01:54 PM
Clarification.........
Originally Posted by Paulporsche View Post
I don't know where you are located but here in Toronto around this time of year, your cold start should raise the revs to about 2500 or so at first and then gradually lower them to about 900 after about 4 minutes or so. This will give you an indication for now, without gauges, if your WUR is operating about as it should.
Paul,
Maybe you meant AAR instead of cold start valve? The CSV does not cause the engine speed to increase during a cold start. The auxiliary air regulator does.
Tony
Old 03-30-2021, 08:58 PM
Heck, I’m only 5 not 71!
targa80's Avatar
Originally Posted by boyt911sc View Post
Paul,
Tony
The warm up regulator (WUR) raises the idle on a cold startup and gradually lowers as the bimetallic strip is heated up. The WUR lowers the initial control pressure in the fuel distributor to~2 bar based on outside temperature causing the higher RPM’s. As the WUR is heated the RPM’s will lower to set idle speed because the control pressure in the fuel distributor is raised and will peak at ~3.6-3.8 bar for normal control pressure at idle.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 03-30-2021, 09:50 PM
"The warm up regulator (WUR) raises the idle on a cold startup and gradually lowers as the bimetallic strip is heated up. "
NOPE!
Old 03-31-2021, 05:19 AM
targa80's Avatar
NOPE!
I believe we are all trying to help Swazzy with his posted issue by providing a pointer to possible causes for his problem. So, please allow me to expand on my post with some additional comments since I understand that if you increase fuel delivery By the Warm Up Regulator (WUR) that will increase enrichment and that will increase engine RPM's. While the air delivery is initially established by the Auxiliary Air Regulator (AAR) and the vacuum side of the throttle body set by the cold engine at a certain level. I will humbly apologize for my ignorance if I have misinterpreted the functionality based on the technical data on the WUR and the AAR that Bosch engineering has provided in the Bosch Gasoline Fuel Injection System K-jetronics Technical instructions. The WUR and the AAR establishes the increased RPM's at startup (Automatic Choke Function) and the smooth operation at startup. Failure of the WUR or the AAR will effect the initial smooth startup (loss of the Auto Choke Function). It should be noted that any false air leaks in the vacuum side of the throttle body will effect startup and smooth operation once the engine is warmed up. As a side note, I just completed an overhaul of my K-jetronics with Lambda fuel injection system and it functions as designed. I have not disconnected any of the components to mask any issues that do occur with this fuel injection system. It is my opinion that if the K-jetronics system is fully functional and maintained it will provide a very enjoyable driving experience.
Pat Henry
Targa80
Old 03-31-2021, 06:59 AM
Designer King
Paulporsche's Avatar
Hi Tony.
You are right, of course, that the CSV doesn't raise engine speed, but that isn't what I wrote. Look again very closely at my post. I said "your cold start" not "your cold start VALVE", meaning " happening at a cold start" , not "via the cold start valve".
Anyway, it's funny, I was just sitting at home doing something else and it suddenly popped into my head that what I said may have been misleading, and I was just going into the thread and correct it to point out the function of the AAR v the WUR, but you and gomezoneill beat me to it! LOL. Thanks for doing that, and sorry if I misled the OP. I was trying to help him check on his WUR before he got his fuel gauge, but incorrect info won't help him.
As Tony has pointed out, the auxiliary air regulator (AAR) raises the idle speed at cold start and then lowers it to normal idle speed over time. The WUR changes the control pressure, varying the mixture so it is correct at any given temperature. If not coordinated correctly with the AAR the engine speed could be wrong during the warmup period and beyond.
Pat,
I've found with my engine, a too rich mixture can also cause the engine idle to decrease. This is why I think Swazzy should have his mixture setting checked, as well as trying to vary the air bypass screw setting.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Last edited by Paulporsche; 03-31-2021 at 02:59 PM.. Reason: Clarification/correction of earlier statement
Old 03-31-2021, 01:35 PM
You are indeed correct........
Hi Tony.
Anyway, it's funny, I was just sitting at home doing something else and it suddenly popped into my head that I was mistaken in what I said, and I was just going into the thread and correct it to point out the function of the AAR v the WUR, but you and gomezoneill beat me to it! LOL. Thanks for doing that, and sorry if I misled the OP. I was trying to help him check on his WUR before he got his fuel gauge, but incorrect info won't help him.
Pat,
Paul,
I misread your post. You are indeed correct.
Tony
Old 03-31-2021, 02:10 PM
Thank you all for continuing to comment. I have a lot to learn!
__________________________
1979 911 SC Coupe CIS 3.0 • Petrol Blue Metallic • 202,000 miles
Restoration in progress.
Old 03-31-2021, 02:41 PM
Very rarely is Tony ever wrong. HE'S THE MAN.
Old 03-31-2021, 05:39 PM
Ok heres the latest and again very appreciative for feedback:
Ivan, I did have to make a slight adjustment to the sensor plate but not much.
The bigger issue now is I did the fuel pressure test. the bad news is I'm so new at this that I did not know that the whining noise while I was doing it was probably the injectors flooding the engine.
The results of the test were not promising either:
WUR Ohms seemed good at 25.7 at 65 degree F temp.
System pressure seemed ok at 72 PSI, and the rest is downhill -
control pressure reached about 15 psi
about the same with warm control pressure - 15 psi although maybe I did not leave it on long enough after I plugged the WUR back in.
lastly there was essentially no residual pressure. dropped to zero in about 10 seconds.
Question are -
How do i resolve injectors that are spraying fuel when they should not be?
Where is the cold and warm fuel pressure, and why does the residual drop so quickly?
Frankly I'm hoping I'm doing something so completely incorrectly that it's not a difficult fix.
I suppose I should add that on the initial break in of the engine it ran fantastic as I varied the revs from about 2200 to 2800. for 20 minutes....
Appreciate the help,
Marc
Old 04-02-2021, 12:37 PM
If your injectors are spraying with the ignition on your sensor plate maybe set wrong also the enrichment screw maybe set too rich. Best figure it out before you ruin your engine. Pull the injectors and use cans or jars so you can see the fuel delivery and post a video.
Old 04-02-2021, 01:07 PM
Red Line Service
Marc Bixen's Avatar
You may want to check fuel volume delivery. Is it possible there is a clamp on a fuel line, or a cap was left in a hose during assembly and/or installation.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 04-02-2021, 01:53 PM
Thanks, heres more info:
I tested the injectors as gomezoneill suggested. They indeed spray when pump is on however they will go off if I push down on the pressure plate. After confirming this, i removed all spark plugs and turned the engine over a few time and pushed the gas out of the cylinders. There was some but not much.
What is the adjustment on the mixture control unit that will put the FD in the closed position when the sensor plate is properly flat?
Old 04-02-2021, 02:00 PM
proporsche's Avatar
did you do any adjustment on the sensor plate with the engine cold or the system completely empty??? looks like you have it wise open if the injectors are spraying..
as mentioned in another thread today...
Old 04-02-2021, 03:33 PM
I made a slight adjustment with the engine cold and no pressure in they system. Is this the only adjustment to be made on the mixture control unit? It seems like the position where the plate rests correctly does not fully engage the plunger/valve in the fuel distributer to shut off the lines to the injectors. It also feels like there is some resistance in the up/down movement of the plate as it operates the plunger/valve. I do not believe this is normal, right? BTW the FD and WUR have been rebuilt, of course they could still be problematic.
Old 04-02-2021, 04:02 PM
Fuel distributor...........
The FD plunger might not be fully going down by itself. Inspect and test the movement of the plunger. As suggested earlier, pull out all six (6) fuel injectors and place them in suitable containers.
Test run the fuel pump. There should be no fuel delivery from any injector/s when the FD plunger is at rest or down. If you get premature fuel delivery:
  • The mixture setting could be too rich.
  • The fuel injector/s could be leaking.
  • The o-ring/s inside the FD could be defective.
  • The FD plunger is stuck up high.
  • You may have a leaking FD.
Any of the above could be the culprit. Test and verify.
Tony
Old 04-02-2021, 05:15 PM
proporsche's Avatar
Well..you have a obvious problem.The movement has to be absolutely free smoth....looks like your fuel distributor pin is getting stuck
Ivan
Old 04-02-2021, 05:23 PM
targa80's Avatar
Question are -
Marc
The Following is from the CIS Service Guide and will provide you with the correct way to connect the pressure gauge and test your fuel pressure, control pressure and residual pressure. Due to limits of posting JPG's I will follow this post with another with 3 more JPG's
Pat Henry
Targa80
Old 04-03-2021, 07:07 PM
targa80's Avatar
Here are three more JPG's of the CIS Service Manual.
Pat Henry
Targa80
Old 04-03-2021, 07:10 PM
