1988 3.2 Alternator Wiring Harness
Having pulled my alternator to have it rebuilt it was obvious that the main live cable had seen better days. Lots of heat damage visible. I had (naively) thought I could strip it back and re-insulate but it looks as though I need to replace it.
Does anyone sell an alternator wiring harness as a ready-made item? I'm in the Uk so a local supply would be good.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 03-29-2021, 06:41 AM
ROW '78 911 Targa
timmy2's Avatar
I make them, but Kroon wiring in The Netherlands is more “local” to you.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-29-2021, 07:40 AM
I HIGHLY recommend Dennis, timmy2. I have lots of his harnesses and all are high quality and labeled for dummies like me. He's easy to contact and stands behind his work.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-29-2021, 07:54 AM
al lkosmal's Avatar
Dennis (Timmy2) makes the harnesses for my EFI kits...highly recommended.
RGruppe #669
http://www.x-faktory.com/
Old 03-29-2021, 08:01 AM
That's what typically happens when the battery is reverse jumped continuously.
Dave
Old 03-29-2021, 08:19 AM
I've owned the car for the last 20 years, had 43k miles on it when I bought it.
Never been jump started in my tenure.
What would cause what you describe?
Old 03-29-2021, 10:01 AM
John W
Those wires definitely got hot. Either the engine got extra hot or a heavy current drain somewhere in the electrical system or a combination of both. Make sure all grounds are good.
Old 03-29-2021, 10:33 AM
ROW '78 911 Targa
timmy2's Avatar
Definitely look for and eliminate the source of the problem before installing a new harness.
Usually the alternator to engine case ground melts as well on reverse polarity. (Looks ok in your photo)
This looks more like a short to ground elsewhere. Maybe in the existing engine harness or at the starter if the damage to the main cable goes that far.
Dennis
Old 03-29-2021, 11:31 AM
Then previous owner or garage may have caused the damage. The same wiring damage occurs when a battery is installed backwards.
Dave
Old 03-29-2021, 06:03 PM
Remember, the case of the alternator makes the major ground, and the wire ground just supplements it.
Dave
Old 03-29-2021, 06:05 PM
ROW '78 911 Targa
timmy2's Avatar
Yup, key word was usually.
After 40+ years fixing high voltage high/current faults, the juice goes wherever it wants to...
Dennis
Old 03-29-2021, 07:54 PM
Thanks for your replies guys!
I'm torn between making up a new cable for the Alternator to starter motor alone, or biting the bullet and springing for a harness from Kroon. (Or @timmy2 if you make one/have one).
The new harness seems like overkill though.
Time to get the car up in the air and remove that red cable.
Old 03-29-2021, 09:32 PM
ROW '78 911 Targa
timmy2's Avatar
The red cable is sheathed along with just a few wires going straight back to the starter.
If the other wires are undamaged, just replace the red cable. (Reverse switch wiring, yellow solenoid wire, oil switch wiring) You might have “fun” trying to pull the cable out of the engine tin grommet...
Use some good harness tape to replace the old vinyl sheathing you will have to remove.
Most harnesses before 84 were wrapped in tape anyways.
Dennis
Old 03-29-2021, 09:46 PM
I have ordered an engine wiring harness from Kroon.
I'd rather do this job right and do it once. There may be damage to the other wires, and anyway it's all 33 years old.
The car has quite a high agreed value and I'm not planning on selling anytime soon.
It's not that expensive and the labour is all mine.
Old 03-30-2021, 10:39 AM
Kroon Wire Harnesses
Carrera 3.2 engine harness
Thank you for your order.
Always on stock so it will be shipped tomorrow !
Regards from the Netherlands.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 03-31-2021, 08:27 AM
ROW '78 911 Targa
timmy2's Avatar
Say thanks, Gerald...
Dennis
Old 03-31-2021, 04:01 PM
I almost forgot !
Thank you Timmy2 !
Old 03-31-2021, 09:46 PM
Thanks.
Would have been great to have an update via e-mail though!
Old 03-31-2021, 11:18 PM
Bank payments always take a few days :-) But its on its way to you (see the updates from our webshop)
Old 04-01-2021, 03:25 AM
Thank you!
Old 04-01-2021, 03:39 AM
