What a PITA.
I occasionally do a double clutch from 2nd into 1st. But the rest of the time NO WAY. There must be something badly wrong with this guys gearbox if he deeds to do this every shift. Sure wear and tear, but I'd rather do a rebuild every 20 years instead. And I know how to double clutch; I used to be a truck driver back in the old - no syncro days. |
You know what else prolongs the life of your car? Keeping it parked. |
I don’t really have issues shifting. But I figured I’d give this a try. Honestly it didn’t feel any better with respect to matching speeds. If anything it felt like I was forcing it more. Any thoughts on why?
I tried a few different methods, and I’m not a novice shifter, I felt like I was double clutching evenly and getting it into gear but it never felt like it was going in as easy as when I do it my normal way. Usually when I downshift I blip the throttle up past 3k right before putting it into the lower gear and this works fine.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
At first I thought this video was at bit unnecessary, but there has been so much good feedback on it that I guess it was helpful. Folks really didn’t know what double-clutching meant? Turns out some didn’t. It really does mean pressing the clutch in twice. It’s not mandatory, but there’s a place and a time for it.
Ken 1986 930 2016 R1200RS |
Another View
Not nearly as in depth as Knightrace - but another video, with me doing my best to describe what occurs as you double clutch:
BTW - I'm with Bill and others, drive it hard but well and rebuild every 20 yrs...
Don "Gordo" Gordon '83 911SC Targa |
One other thing about shifting, my opinion. Nearly ever car I've owned since I was 16, now 77, has had a clutch. I've learned to heel and toe and double clutch. Matching the rpm before releasing the clutch. In all those years I've never used up a clutch. Now when I've pulled the engine for what ever reason I always replace the disc, pilot and throwout bearing and the old disc always looked ok.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
During a drivetrain drop after 27,000 miles, I measured the clutch disk lining thickness. The spec for a new clutch is 8.1 +/- 0.3mm. The measurement below with my low-buck digital vernier was close enough to spec to indicate double-clutching results in minimal clutch slippage (and wear) as it happens during typical take off and up/down shifting. ![]() As for double-clutching, here's an easy low-speed practice routine. On an empty road: 1. Bring road speed up to a steady 20 mph in 4th gear. 2. Shift to neutral, then engage the clutch (pedal up). 3. Rev the engine a few hundred rpm above the normal rpm it would be in 3rd gear (e.g. 1500 rpm at 20 mph in 4th > 1800 + 200 rpm in 3rd) 4. Depress clutch during step 3 and complete the shift from 4th > 3rd The engine speed and shift transition between step 3 and 4 should be seamless. Experiment with various pre-shifting engine revs. Practice until you get it as close as you can. Practice the same 4th > 3rd gear downshift at different vehicle speeds. Remember that 1st and 2nd gears provide the most torque multiplication and require more engine revs when downshifting into those gears. Here's a 901 gearbox chart that graphically shows vehicle speeds at each gear position. Compare the relative engine speeds between 3rd and 4th gear at 20 mph, then between 1st and 2nd. Adjust the revs accordingly. ![]() Sherwood |
Great video - thanks.
'80 SC Targa Avondale, Chicago, IL |
