l_turn9's Avatar
06 E350 Radiator Hose Clamp Releases
I need to remove a radiator hose but it has some kind of hose clamp I have never seen before. I checked the manual but don't see an easy way to release them. I'd like to remove them so I can re-use them, if possible.
Thanks!!
Happy Easter!
Old 04-04-2021, 10:36 AM
Senior Advisor
James Brown's Avatar
i looked and mine does not have any water in it or a radiator
08 Cayenne Turbo
Old 04-04-2021, 10:37 AM
You mean it is a 2006 Mercedes? You are obviously posting on the wrong forum. Although, had you included a picture, some of us here might be able to offer an opinion.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-04-2021, 11:04 AM
l_turn9's Avatar
I'm sorry gang! I also have a 911 and forgot to look to see which forum I was on. Sometimes I get focused on my task and end up with tunnel vision!
Thanks for the re-direction -
No water? No radiator? ;-)
Larry
Old 04-04-2021, 12:33 PM
RETIRED
Joe Bob's Avatar
Germans like to repeat themselves....post a pic. West coaster members can be dicks....I know, I used to be one. %^)
2012 ML350 3.0 Turbo Diesel
Old 04-04-2021, 05:08 PM
l_turn9's Avatar
Thanks Joe! I went out and looked at it more closely and found a clamp I could see more easily. It looks like I can push a thin screw driver under the wire and lift the clamp up and back. I believe it will come off with little trouble. I appreciate your reply Joe! I need to put a container under the hoses to catch the fluid that will pour out. I'm removing the Alternator and everything is harder than it looks at first. I will need to remove one end of the rad hoses to provide room for the alternator. When I tried pushing the hoses out of the way, they just refused to push far enough out of the way for the alternator to fit past the hoses and engine (naturally). So l
left everything where it was and did some research. It seems the suggested method is to drop the Alternator down past the suspension, but there is no possible way for it to fit that way. That's when I decided I would need to remove a hose (at least one end) to provide enough space. Man! I thought working on the Alternator and starter on my 911 was tight! This W211 beats it in the difficulty factor by a country mile! I've always liked the ML but I decided no more MBs unless it's a diesel! We had a '91 300D we absolutely loved and would still own her if the rust monster had not eaten her! Great mileage and easy to work on with comfort and luxury all together! Loved that W124.
Unfortunately I may have to give up my 911. After 4 failed knee replacements my clutch leg has gotten too short to effectively reach the clutch (they trim the bones a bit each time). I have been considering trading for a Tiptronic Cayman or 911....
Thx again -
Larry
74 911
06 E350
Old 04-04-2021, 05:59 PM
GG Allin's Avatar
I was imagining a heavy duty Ford Econoline.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 04-05-2021, 06:31 AM
MBAtarga's Avatar
Is it an Oetiker brand clamp? Just replace it with your run of the mill hose clamp from your FLAPS instead.
https://www.oetiker.com/
Mark
'83 SC Targa - since 5/5/2001
Old 04-05-2021, 07:47 AM
