1979 911 SC
Sway bar diameter question
I'm getting ready to order new sway bar bushes and drop links for my 79' SC. It's stock as far as I can tell. I put a caliper on the front and rear sway bars to make sure and get the correct sizes and I get a 21+mm reading on the front and 18+mm for the rear. I was sure that I had read that 20mm was stock in the front and this is probably a silly question but when ordering my bushes should I be looking for 21mm or 20mm for the front? I appreciate any advice.
Old 04-13-2021, 05:04 AM
My '77 has 20mm front and 18mm rear bushings FWIW
Sent from my SM-G998B using Tapatalk
'77 911 Targa - currently in bare metal
Old 04-13-2021, 05:40 AM
Bill Verburg's Avatar
The oe spec for a '79 SC is 20/18
This was the same for Carrera 3.0 and SC from '76 thru '83
and for carrera in '84 & '85
for '86 they went to 22/21
Bill Verburg
Old 04-13-2021, 09:04 AM
Just a tip that the correct pn for the rear 18mm bushing seems to be way undersized. I ordered bushings 477-411-313-C which is for a '85 Turbo 20mm rear sway bar and they fit my 18mm bar perfectly (78 SC).
Question about rear stock sway bar bushings on an SC
1978 SC Targa
Old 04-13-2021, 09:38 AM
