911 pertronix c/d problem 1977
Can some one help me. When I turn over the engine it does not fire until I let the key go. I am sorry. The cdi unit is made by PERMATUNE .Thank you.
Check to see if voltage is sagging while your cranking. May need a new battery. Or ground wires need to be cleaned.
Save yourself some headache, Get rid of all things Pertronix . For 35 years I have been fighting them
Go back to points if you have to. Permatune is fine . Look into the 123 distributors Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Pertronix work fine. Check your wiring... and you're sure the CDI is OK and your timing/pertronix setup is good?
45 years in the biz of vintage racing and there is nothing worse than Pertronix
Just my opinion Every one that I have ever come across has failed They even admit that average life is less than 4000 miles , and racing ? no warranty at all.
