-   -   2.7 will not run well after CIS rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/1091829-2-7-will-not-run-well-after-cis-rebuild.html)
Ginger77 04-24-2021 02:23 AM
It's spring so I'm reaching out for help with my CIS rebuild. I literally spent too much time fiddling, reading about all the vital topics that have accumulated on Pelican over the years. I have learned so much but I'm getting demotivated because I'm struggling to get my engine to run. Also my 911 needs to go to biannual inspection and I've already missed the due date.
CIS is rebuild: I renewed all gaskets, rubber o-rings, injector sleeves, intake rubbers, rubber crosspipe behind the airbox. I purchased an aluminium airbox from a Pelicanite to make sure I'd not have air leaks.
The FD is rebuilt with a Missing Parts rebuild kit and checks out with 4.7 bar SP and I tested the flow. I don't currently have the data at hand but the flow matched the spec.
I made my WUR adjustable using the invaluable info here on the forum. I also purchased new WUR springs and a permanent pressure gauge kit from a german Mercedes parts store to control and monitor my pressures. The heating element gives a nice 26 Ohms resistance. I used this great step-by-step Mercedes Benz manual to test and calibrate my WUR. The manual goes through all the steps where I ran the WUR without the sombrero too.
For reference. The control pressures are as follows for my 1977 2.7 033 WUR.
CCP 1 bar (13 degrees C = 55F) 15 PSI
WCP 2.9 bar (takes about 6 minutes) 42 PSI
WCP 3.3 bar with vacuum 48 PSI
These are according to spec given the workshop info I'm using.
I installed an AEM AFR gauge to monitor mixture.
Out of precaution I renewed the fuel pump as the old Bosch had an irregular whine during control pressure testing. New pump is a Pierburg item and I put in a new Mahle KL-25 filter.
The vacuum lines are correct where the bottom of the 033 WUR goes to atmosphere above the throttle plate. The top of the WUR goes to the side of the thermal valve and the center of the thermo valve tees the distributor and throttle housing below the plate.
http://forums.pelicanparts.com/uploa...1619255947.gif
When I checked the AAR it closed in 5 minutes.
I purchased new injectors because some of the old ones dripped.
I set mixture to where the injectors spray and then backed off a half turn.
The engine starts up and revs up to 1800rpm with an AFR of high 11s. Then comes down as you'd expect from the AAR closing and control pressure rising. But after a few minutes the engine runs super rich. AFR is in the 9. My eyes get watery and my 911 is parked underground. Unfortunately, I've set of the CO alarm twice already.
https://youtu.be/CgmPFwfwgSw
The sensor plate is vibrating like crazy. And the needle in the little control gauge is playing pinball. What is happening here?
My assumption was that perhaps the CSV is not shutting down since backing off the mixture has no effect at this point. This would make the CSV run super rich. Or something is up with the vacuum such as the signal to the thermo valve. Does the connector go a specific way? It seems that when the TTS reaches a temperature something is up with either vacuum because the WUR gauge is all over the place. Or there is way too much fuel?
Since the CSV is controlled by the Thermo time switch. I took the TTS out. The resistance checked out low. The Bosch manual states the following values and mine are in bold:
Below 104F
G-Ground 30-40 24
W-Ground 0 0
G-W 30-40 24
Above 122F
G-Ground 55-85 60
W-Ground 0 98
G-W 55-85 40
I bit the bullet and purchased a new item which doesn't give any resistance values on my multimeter.
https://www.vankesselsportscars.com/...3264-7889s.jpg
I have a spare CSV that I intend to test too. But first I want to see what the new TTS does. Although I don't want to void warranty on a €200 item. However, it came in a Porsche box stating the quality has been checked.
My car is not parked at my house and I won't have time to go out again until tomorrow afternoon. But I'd very much appreciate any help here. I feel that I've tested the components and probably renewed more items than I would have needed (in retrospect) but I must be in at around €1500 of parts by now and I can't figure out why the engine won't run well.
Much appreciated.
runner4fun 04-24-2021 06:36 AM
No expert here, but I had to replace my CIS fuel distributor with a rebuilt unit.
Walter_Middie 04-24-2021 07:13 AM
Check that your CSV only gets power when the starter motor is engaged. The plugs for the WUR and CSV are the same, and can be mixed up. The WUR gets power all the time. That may be the easier check - to ensure the WUR is not getting power only when the starter is engaged.
fanaudical 04-24-2021 07:20 AM
Have you attempted to set the idle mixture and speed once the car is up to temperature? I think a 2% CO content is around 13.8 AFR. Also, have you verified position of the plate in the airflow path?
boyt911sc 04-24-2021 09:39 AM
Clarification.......
Walter,
Physically impossible for WUR’s plug to get mixed up with the CSV’s plug even if you try it. Maybe you meant CSV and AFM sensor switch getting mixed up. Keep us posted.
Tony
47silver 04-24-2021 09:51 AM
Did you have to remove the air flow plate? If so how did you calibrate it? I used cigarette rolling papers and set them around the plate. The papers are very close to the specs. Worked for me and that was 10? Years ago
Walter_Middie 04-24-2021 09:54 AM
Tony,
The switch between WUR and CSV happened to me. It is easy to do. I had to tow my car to John Walkers where he diagnosed the problem in 30 seconds - as he was familiar with this issue. The electrical connectors in 1975 were exactly the same for both of these.
Dave Kost 04-24-2021 10:08 AM
The proper way to set the initial mixture per Larry Fletcher CIS Flowtech. He includes this procedure is the box with the rebuilt fuel distributor.
After assembly of the fuel system, run the fuel pump and depress the air flow sensor plate for a couple of seconds to bleed air out of the fuel distributor. Remove one injector line from the top of the fuel distributor, and while looking into the injector port in the top of the fuel distributor turn the mixture adjustment screw clockwise until the port just starts to fill with fuel then turn the mixture screw 1/2 turn counter clockwise. Reinstall the injector line, start the engine and adjust mixture when it reaches operating temperature. This is the Bosch recommended procedure for initial mixture setting and adjustment.
Then set the CO and rpm to spec.
Let us know how this works.
boyt911sc 04-24-2021 10:48 AM
Don’t be offended........
Originally Posted by Walter_Middie (Post 11308687)
Tony,
Walter,
The problem with accidental switching or mixed-up of the electrical plugs happen only between CSV & AFS (airflow sensor) switch NOT with WUR. For the sake of discussion, go to your car and take a look. The WUR’s plug won’t reach either of the CSV nor the AFS switch. But CSV’s and AFSS’s plugs often get involved with this blunder. You might have misunderstood JW.
Tony
Walter_Middie 04-24-2021 10:54 AM
Tony - do I have an AFS? The fuel pump runs with the key on - no waiting until it starts to crank.
It would make sense for Porsche to Murphy proof these at some point, as I can't be the only one to make this mistake.
My car is in the body shop for some minor rust repair right now so I can't run out and check, but I remember the wiring harness was routed incorrectly to make the wrong connection possible - the wires didn't reach easily - as you said.
boyt911sc 04-24-2021 11:39 AM
No AFSS ...........
Walter,
Your ‘75 does not have an air flow sensor switch. It was introduced in 1976 models up to the last SC (1983). We are discussing about Ginger77. The wiring harness for this particular CIS model has the CSV & AFM plugs tucked close each other. While the WUR plug is about a foot away from these 2 plugs.
It is physically improbable to get the WUR plug hooked up to either CSV or AFM even if you intentionally want to do it. The ‘77 engine wire harness has four (4) similar plugs namely:
  • WUR (Gray)
  • AAR (Black)
  • CSV (Blue)
  • AFS (Green)
The blue and green plugs are the ones commonly get mixed up because they are tucked too close to each other in the engine wire harness. The two (2) plugs (gray & black) are too far away from the rear.
Are you even familiar how the engine wire harness is laid on top of the Fiberglas shroud? With the 14-pin connected, the WUR (gray) plug won’t reach the CSV.
Tony
Dave Kost 04-24-2021 02:07 PM
The above is the initial settings to get the car running. What this does is it gets the plunger of the FD (fuel) and the AFM plate (air) in position so the car will start.You didn't do it right. (See above) Then make your adjustments to get the CO and RPM to your engine specification.
Did you try setting the CO and RPM by adjusting the 3 mm allen screw and the air by pass screw on the throttle body? (You don't mention it.) You do this at warm idle.
Less fuel - 3mm screw counter clockwise
Less air - air by pass screw clockwise
You should be able to bring the engine rpm down by closing the thumb screw.
You probably know this but you didn't mention doing it.
Why not a Bosch pump? 9 AFR is just off the charts rich!
fanaudical 04-24-2021 05:44 PM
I think the procedure that Giner77 lists does match the factory procedure. Here's a link to a post with pics of the factory procedure:
http://forums.pelicanparts.com/porsche-911-technical-forum/803825-cis-starting-point-after-fixing-leaky-system.html
Regarding bouncing sensor plate and buzzy gauges - Does it run better if you disconnect your test gauge?
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/432213-bouncing-air-flow-plate.html
Another link that may be useful:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/749247-airflow-meter-plate-moves-fp.html
Ginger77 04-25-2021 07:04 AM
Thanks for the replies. Just to provide some answers. I did not remove or alter the position of the metering plate in the process. And this has not occurred before.
Like Tony says, the connections behind the air filter housing have specific colours and I'm afraid the problem is not as simple as mixing them up. Also there's no way the WUR can reach there. I've spent enough time around the assembly to know where all connectors go.
Why a Pierburg pump? Because there really good. :)
http://forums.pelicanparts.com/uploa...1396236500.jpg
Also, I set mixture according to this manual. But it's hardly possible to adjust mixture when the metering plate is going crazy. I know you're supposed to tune mixture and idle speed with a warm engine. But in the current state there's no way my engine can reach operating temperature. Also the RPMs in the clip are around 800. Very low, very rich.
I noticed that the vibrating metering plate almost exclusively happens to 930 turbo engines. Why would that be? As for my fuel head: All rubbers and o-rings have been renewed in my FD. Including the pressure regulator parts:
http://forums.pelicanparts.com/uploa...1275382245.jpg
I saw a mention of people who had said it was due to their fuel pressure gauges. But then elsewhere I saw them mentioning is was due to something in the end.
Most CIS topics are like a quest where I would be send off to measure this or that and then come back to exclude items or pinpoint the problem. What could I check at this point?
I can verify the position of the metering plate according to this manual:
http://forums.pelicanparts.com/uploa...1619359189.png
I can take the Mercedes fuel pressure gauge out of the equation and hook up my CIS gauges again.
I can unbolt my FD and see if the plunger still moves freely and has no scoring.
Anything else? I wish I could swap out the FD but I don't have a second.
Should I still swap out the TTS or would I be better off returning the $200 item?
Ginger77 04-25-2021 07:26 AM
I accidentally posted the downdraft paragraph of the metering plate height adjustment. Here's the correct updraft:
http://forums.pelicanparts.com/uploa...1619360769.png
But my '77 has a screw for adjustment and not a clip.
Dave Kost 04-25-2021 09:38 AM
Thanks for the up date and clarity.
I would lean out the 3 mm mixture screw a full turn and start it up again. Also, one of the jobs of the fuel accumulator is to dampen the fuel pump pulses so, I would check it too.
If it were me, I would put the old fuel pump back in.
Why did you decide to rebuild the CIS system? Any particular reason?
Ginger77 04-25-2021 02:24 PM
I had intake leaks. The car would keep on coasting when I'd approach a red light.
I'm glad I did when I started. Some injector sleeves had disintegrated.
pmax 04-25-2021 04:02 PM
Hi,
In your 77, there's an CIS elf called the thermovalve (Not the TTS) which can muck with your FP.
I haven't seen you mention checking it yet. Search for these threads.
Here's a description from the CIS Primer, if you haven't already seen it, #4 in the diagram.
https://jimsbasementworkshop.com/CIS/pages/descr_midyear.html
http://forums.pelicanparts.com/uploa...1619390328.jpg
BTW I doubt it's your CSV. The other little CIS elf is that decel valve #8 which should not be doing anything except in decel conditions which I assume you are not testing under, but if misbehaving could muck with your car running well. So, I would consider eliminating it from the puzzle by taking it out, just for testing purposes, although many do it permanently since it is apparently for emissions and can hang up your throttle on lifting. Porsche got rid of #4 in later versions of the CIS.
Good luck !
Ginger77 04-26-2021 12:31 AM
Before the rebuild I did not have a thermo valve. I sourced an NOS item so I'm thinking it's not malfunctioning. But please let me know how I can test the item.
Also the acorn decal valve holds a half bar vacuum when I use my Mityvac. This indicates it functions as it should. Correct?
Furthermore, I'm also aware that the diagram above is incorrect for my 033 because the WUR connections are swapped. Vacuum (top) and atmosphere (bottom) as the note at the bottom mentions. And the top of the decel valve goes to the back of the throttle body. No tee here. But there's a tee from the distributor and the front vacuum of the TB going to the center connection of the TV. I'm referring to the very first diagram I posted at the top of the page.
I first want to focus on the FD. I'll unbolt it from the housing and see if the plunger is sticking. And I'll pull the pressure regulator. To see if that assembly moves freely.
pmax 04-26-2021 10:52 AM
Did you read the link someone posted previously ? It said the gauge kit could be a cause of the fluttering, and you have one installed.
Your CP numbers above might be right, looks OK to me, but those assume the vacuum is in spec. All I'm saying is #4 plays a main role there. So, the PO deleted the unit. I can understand why since that reduces the number of variables, elves I call them and complexity which is the opposite of what you're embarking on.
Ginger77 04-26-2021 11:06 AM
Yes. I read all of the links. In the end I found the same user stating elsewhere that the vibrating persisted and he found his ignition box was the culprit. However, there was another person that blamed the gauge. I'll go back to my larger pressure test kit.
Is there any way I can test the thermovalve or would you suggest me to reroute the vacuum lines and take the thermovalve out of the equation for now?
I suppose I'll install the new TTS too. Assuming it works in spec despite me not getting any resistance values with my multimeter.
pmax 04-26-2021 11:21 AM
If you’re asking what I would do if this were my car, I would remove the darn thing, set the CCP/WCP per no/vacuum spec respectively and see how it idles cold and warm but not suggesting you do the same lest angering the Porsche gods, it’s up to you.
boyt911sc 04-26-2021 11:34 AM
Incorrect information.........
Originally Posted by pmax (Post 11310017)
...........(edited)...........
Good luck !
That is not correct. The thermovalves were still used to the last ‘83 SC’s using vacuum assisted WUR’s (-069/-089) and and the SC’s with lambda system switched to non-vacuum assisted WUR’s (-072/-090). Thermovalves are used with vacuum assisted WUR’s.
The decel valves that are out of spec or defective cause premature valve opening during heavy deceleration. The solution is to fix and recalibrate the decel valve instead of removing them. The lack of understanding how the decel valves operate and how to correct the problem resulted to their elimination or removal from the system.
This is like having a patient coming to your clinic limping with a bad or swollen foot, instead of diagnosing the problem you decided to amputate the bad foot to eliminate the problem. Now, you made a bad situation worse.
Tony
pmax 04-26-2021 11:42 AM
Unless there's a thermo valve in my 80, it's absolutely correct. ;)
Tony
Decel valves function during deceleration and are supposed to get out of the way, doing nothing otherwise. The failure of the latter non-function is where it matters to me.
Ginger77 04-26-2021 01:11 PM
So, I spent some time after work and dinner taking items off and inspecting. First up was the FD and I soon discovered the plunger was not sticking. It felt well lubricated so it can't have been the culprit. I took out the fuel pressure regulator and that felt fine too. I took out the assembly, inspected, assorted the shims and put it all back together. For reference, there's 4 shims in there that measure 3mm in total. I put in 2 more during the rebuild to see if I could get the pressure near to 5 bar but it remains in the 4.5-4.7 bar region. That was the case with the old Bosch pump and filter as well as with the current Pierburg pump and new Mahle KL-25 filter.
I also checked the metering plate height. However, after rereading the Robert Bosch manual it states the metering plate height should be measured in the presence of control pressure. I thought I had found a low metering plate but I'm afraid it will rise when the FD receives pressure and is probably in spec. Correct? I need to check when the FD is back on.
http://forums.pelicanparts.com/uploa...1619467201.jpg
Lastly, I took out the little pressure gauge. Tomorrow I intend to put stuff back together and test pressure with the larger pressure gauge from my kit. However, by now I have tried and tweaked all the settings of CIS. That also goes for the throttle body. Is there a base setting for the throttle plate stop screw and the idle screw?
http://forums.pelicanparts.com/uploa...1619467420.jpg
I'm noticing 3 visible threads on the stop screw and now that I took the rubber top piece off I can look into the TB. How far should the idle screw reach? This might be an irrelevant question with regards to my issues but there's nothing wrong with trying to get a good starting position :)
http://forums.pelicanparts.com/uploa...1619467788.jpg
All in all, I can't pinpoint the issue. I would very much appreciate any thoughts and input.
47silver 04-26-2021 04:58 PM
If gauge used nylon it may pulse. Need to use polymid
Ginger77 04-26-2021 09:54 PM
It's PA hose
boyt911sc 04-26-2021 10:50 PM
Rest position of the sensor plate.......
Diederick,
It would be the other way around. When the FD is under pressure, the plunger will have the control pressure pushing it downward not upward as you stated. The rest position of the sensor plate is determined by the “pin stop” located under the sensor plate.
Tony
Ginger77 04-26-2021 11:08 PM
Hi Tony, thanks for chiming in. You may have made a very good point. If the plate lowers even more then it's definitely out of spec. I will assess this later today.
Unfortunately I forgot to take a photo but I'm rather sure my sensor plate is adjusted with a screw from underneath. With that screw it seems I can push the plate up from the arm and then lock the screw again with a tiny nut.
boyt911sc 04-26-2021 11:26 PM
Setting the sensor plate height.......
Diederick,
Correct.
Tony
pmax 04-27-2021 12:24 AM
Tony
Spare me the haranguing. The decel valve delete predates you.
You know what the official fix for an errant decel valve is for the later CIS systems ... crush the pancake, yes, just crush it, just the pancake, not the nipple mind you, but crushing it nevertheless.
http://forums.pelicanparts.com/uploa...1525021612.jpg
There's the precision recalibration for you as instructed by Porsche themselves.
More goodies here ... http://forums.pelicanparts.com/porsche-911-technical-forum/863964-sc-decel-valve-woes.html#post10006879
Back to Ginger !
Ginger77 04-27-2021 04:33 AM
I had a bit of time this morning. I put the FD back on and adjusted the mixture with the other method of undoing one injection line, watching for fuel as you go clockwise and then back off a half turn.
This took me a little longer as for some reason I have a habit of mostly over tightening bolts with copper washers. After cleaning up some fuel spillage and renewing all of the copper washers I hit the Google and found that M8 likes a torque of 9Nm and M10 17Nm this did the trick and all was good.
I then raised the meeting plate. The thread is super fine so it may not look much but I gave it more than a full rotation. How does this look?
After this I checked the cold control pressure with the gauge from the kit and only got 0.5 bar instead of the 1 bar that the small gauge showed. I then ran out of time so I decided to check pressures tomorrow. I have two manometer gauges so I'm going to double check whatever reading I get.
https://uploads.tapatalk-cdn.com/202...835c9953d1.jpg
Paulporsche 04-27-2021 07:22 AM
I tested my thermovalve by removing it from the car and applying a 12v dc power supply to it. When cold (ie no power) you shouldn't be able to blow through it. With power you will able to blow through it after about 25 seconds or so.
The thermovalve comes into play to prevent vacuum from pulling on the lower chamber of the WUR, thereby richening the mixture for a cold start.
boyt911sc 04-27-2021 08:31 AM
Testing a thermovalve.........
Paul,
You can not use pressurized air to test a thermo-time valve and obtained a valid conclusion. I thought the same before I realized that the test was flawed. Instead you need to use vacuum. I had a post regarding this test.
Try it with a good and bad TTV using pressurized air and you will be surprised with your test result because some of the good TTS would fail the positive pressure test but works well with vacuum. It has to do with the design of the disc valve.
Tony
Paulporsche 04-27-2021 09:18 AM
Good to know. Thanks Tony.
In my situation, I tried both sucking and blowing alternatively to test mine. Unfortunately, as I mentioned to you when we discussed this, I think I have lost my diaphragm, so the result was the same.
But, as you point out, since this is a vacuum limiting device, the test should be done using vacuum.
Ginger77 04-27-2021 01:17 PM
I'm not quite sure I understand the method. What is the procedure to test the TV? I can pull a vacuum with my available tools. I have reinstalled my old TTS and I will return the new item if all works well.
Paulporsche 04-27-2021 01:37 PM
Diederick,
If you attach a vac line to the front of the TV where the vac was originally applied you should find you will not feel the vac from the other nozzle when the engine is cold. If you energize the TV you will feel the vac pulling through after about half a minute as the unit warms from the elec current and opens up its diaphragm. I did mine off the car using a 12v source but I don't see why this couldn't be done in situ, since its operation occurs while starting. I think I would just feel for no vac then followed by vac at the line that attaches to the WUR as the engine turns over/starts.
Tony,
I know you test all these components extensively. If you have a different or better procedure, please let us know.
EDIT: I see from 47Silver's PET diagram that the line from the TV goes to the top of the WUR on a 77. On my car, which has an 80 engine set up like a 78/79 with a different WUR, the line goes to the side of the WUR.
47silver 04-27-2021 01:45 PM
cis 77
this is from the pet.
are all connections properly done?
i mentioned earlier that I was able to adjust the throttle plate by laying in cigarette rolling paper around the inside of the throttle body and that set the plate tolerances properly. I wetted the paper a bit so it would stick.
http://forums.pelicanparts.com/uploa...1619556299.jpg
boyt911sc 04-27-2021 09:23 PM
Testing a thermo time valve..........
Originally Posted by Paulporsche (Post 11312238)
Diederick,
Tony,
Paul,
This is how I bench test a TTV (thermo time valve). I call these thermo time valve because it operates under a certain period when energized. And the duration or time involved range from 20 sec. to 30 sec. based from my collected data over the years.
These are some of the thermo time valves in my collection that passed the tests. The bad ones were segregated and stored separately.
http://forums.pelicanparts.com/uploa...1619581861.jpg
The first test is to hook up a hand held vacuum pump and determine if the TTV is good or bad. A 16” Hg is an arbitrary value that I use for vacuum testing WUR & TTV. Look at the gauge, the vacuum should hold or stay steady. And the vacuum test hose is connected to the middle nipple (see picture below).
http://forums.pelicanparts.com/uploa...1619581913.jpg
If it could not hold the vacuum for several seconds, it is leaking and deemed defective. The second test is to apply 12 volts to the TTV and observe how long before the valve opens up. You could hear the valve pops open and watch the vacuum gauge reading drops to zero.
Tony
Ginger77 04-28-2021 12:22 AM
Thank you. I will apply a vacuum to the TTV with my hand pump and see if it holds. Then once the engine is running I'll check to see if it's pulling a vacuum from the WUR by taking the hose of the WUR and putting my finger on it. I doubt it's defective since it came in its original Porsche packaging, never opened, but there's no harm in checking.
And yes, I have used that exact same diagram as a guide for the routing of hoses. :)
Any opinions on the positioning of my metering plate? It's hard to measure 0-0.5mm into the bowl. Perhaps I can use a feeler gauge as there's not enough room to slide my callipers in. As far as the idle screw and TB stop screw go, I think I'm in the ballpark.
So the next job is to test the TTV. Recheck the plate heights. Swap out my manometer for the quality WIKA brand one, retest fuel pressures and adjust if necessary. Then start the engine and see where we're at. How do you feel about starting the engine when you've tested WCP? I feel it's kind of hard to start a cold engine when the fuel pressure is at warm state. The other day I did this and I had disconnected the AAR during fuel pressure testing. So, lean mixture and extra air did not make for a happy engine. Should I let the WUR cool down first?
