Airbox not lining up with AFM
So I’m starting some winter projects on my 88 carrera. Purchased an air flow meter and new airbox but they do not line up when trying to put them in place. What am I missing here? Is there a part that’s needs adjusted? Anyone else experience this?
1988 carrera 3.2 coupe
Old 02-05-2023, 07:34 AM
I recently had mine apart doing the AFM wiper arm "adjustment". I attached my AFM to the airbox first and then put back the car as one unit. Have you tried it that way?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-05-2023, 07:46 AM
I did try that first, but then the AFM would not line up with the opening it goes into (sitting too high) . I feel like theres something around the intake manifold thats causing the airbox to not line up right. But I was able to bolt the one screw attaching the airbox to the manifold you can see in the last 2 photos. Weird
Old 02-05-2023, 08:11 AM
proporsche's Avatar
how about the inside the box mount (behind the air filter)is it on it??Plus have you changed the mont on intake no.4? Looks higher...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-05-2023, 08:25 AM
Problem solved. I’m an idiot. There was one more bolt hiding behind the intake Manifold
that needed unscrewed which allowed the box to be seated properly.
Old 02-05-2023, 08:26 AM
I do have one more question though , is this hook up correct for the AFM. Seems much longer than other pics I have seen . was unable to get it attached first time I tried plugging it in.
Old 02-05-2023, 08:31 AM
proporsche's Avatar
you have to disconnect it from the bottom plug..this is an aftermarket plug
Ivan
Old 02-05-2023, 09:01 AM
Thank you. It still has a red wire attached to it so I cannot remove the after market extension from the car completely. Don’t know if that wire is important , I will have to dig further to figure out where it goes.
Old 02-05-2023, 09:24 AM
proporsche's Avatar
where does the wire go...connected--not original ..
Ivan
Old 02-05-2023, 09:48 AM
Here is where the red wire ends up. Not sure how to remove as it’s attached to another connector. Any idea what the wire is for?
Old 02-05-2023, 10:31 AM
Ok getting close to finishing this job. I think this is the vacuum hose to the carbon canister (correct me if I’m wrong) is the black nipple on the end of the hose correct? , does the hose attach to the back of the airbox? (second pic behind the hole shown) . The black nipple does not feel like it will attach to the back .
FYI, I’ve never work on a car before, no shock there I’m sure.
Old 02-05-2023, 11:26 AM
Old 02-05-2023, 11:29 AM
I dont know why my pics are suddenly not loading
Old 02-05-2023, 11:30 AM
proporsche's Avatar
cut the red wire close to the brown el.cover for the inside wires.After tape it.
that should the job
Ivan
Old 02-05-2023, 12:30 PM
Ok, that should be it. Found out the black nipple was not supposed to on the hose so I removed it and clamped the hose on the back of the airbox. Red wire is that’s left. Thanks guys
Old 02-05-2023, 12:32 PM
