DMX DMX is offline
DMX's Avatar
Unhappy Pertronix ignitor question....
Ok.... Everone tells me to hook up my red wire from the pertronix
ignitor to the number 2 fuse left of the engine compartment
because it has constant power.... I could not unscrew the thing
because it is siezed... so I connected it to the number 1 fuse...
the number 1 fuse has constant power even when the car is
off... Is this good or bad...?
Old 05-04-2003, 01:02 AM
marcesq's Avatar
Bad, I wouldn't give power to anything full time but the radio and the clock.
I don't think that the CD unit (whatever makes the spark signal on the Pertronix) should have power full time. It would be like have the Permatune box on all the time which it is not designed for.
Sorry for the typos it is too early in the morning for my fingers.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 05-04-2003, 01:14 AM
DMX DMX is offline
DMX's Avatar
Why is it bad?
Old 05-04-2003, 01:15 AM
DMX DMX is offline
DMX's Avatar
Ok... I just went into my garage and hooked it back up to the coil like I
had it before....
Old 05-04-2003, 01:30 AM
ruf-porsche's Avatar
Hey DMX
You mean to tell me that you hook up your Pertronix to the coil and it starts? All the expert here said that it needs to be connected to the number two fuse in the engine compartment.
When I had a 74 911 I replaced the point with the Pertronix and it wouldn't start so I put back in the point.
Old 05-04-2003, 03:29 PM
poorsha's Avatar
DMX. I just completed the install of a Pertronix on my 74 today. Worked perfect first time. Email me if you need details. I also took a bunch of pics. poorsha@shaw.ca
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 05-04-2003, 04:07 PM
47silver's Avatar
you should be able to loosen one of the screws on the #2 fuse block? you dont want power on the circuit all of the time as it may keep car running. i posted the other day on how i wired mine up 2 weeks ago. it works great, tach and everything with an msd 6al.
gary
1975 911S Targa
Silver Anniversary Edition
Old 05-04-2003, 06:36 PM
DMX DMX is offline
DMX's Avatar
ruf-porsche
It works... But it did not work with the original coil like the instructions said... I went and bought a super coil and the thing fired right up... It works all the time since....
Old 05-04-2003, 09:15 PM
Alan Cottrill's Avatar
if you connect your petronix red wire to the coil+ and the black wire to the coil- you are not triggering your CD box you are triggering the coil.
do this experiment:
disconnect your CD box, attach 12v to the coil+ and hook up the petronix as I stated above. It'll run. It's "inductive" ignition. Thats how I have it insatlled on my 67 Mustang.
What you want to do is connect your petronix red wire to any SWITCHED 12v power supply and connect the black wire to the wire your points used to attach to.
big AL
'77 911
Old 05-04-2003, 10:17 PM
47silver's Avatar
you will notice a great improvement in low end and power if it is connected properly.
1975 911S Targa
Old 05-05-2003, 11:51 AM
bigchillcar's Avatar
You really noticed an improvement in performance you can feel in the seat of your points...er, pants with the ignitor instead of points? I can handle working on points no problem, can clean them or replace with a spare I keep in the car's toolbox, but I have considered and wondered about the ignitor.
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-05-2003, 01:01 PM
